Old 11-13-2006, 01:20 PM   #1
sprigmo1
sprigmo1's Avatar
sprigmo1 is on a distinguished road
Default Home made smoke screen
OK, went to the Great Falls Meet Sat. had a great time!
On the way home smoke spewing from my catch can filter, then out of my exhaust!
Yes I did have a 100+ mph run before this happened!
Any ideas what it could be before I start pulling things apart?
I figure blown rings, or broken valve stem??????
Soon as you get'em running good..............Uugh!
Malik
" It Ain't Eazy Being Me"
1992 Supra /TSW 618 Rims/Goodridge Brake Lines/Powerslot Rotors/Eibach Springs/Tokico/KYB Struts/ST Sway Bars/Cusco Strut Bars/Targa Bars/RPS Clutch/C's Shifter/Aero.AFPR/RC 560cc Inj/Walbro Fuel Pumps/Lexus AFM/HKS Timing Gears/K&N Intake/HPF Intercooler/Greddy BOV/Turbonetics 60-1 CT26/CSF 53mm RAD /Apexi S-AFC /Apexi AVC-R /Apexi N1Exhaust/RT DP/RT Cat/Jegs Catch Can/Greddy TT/Blitz Boost/EGT Guage/Blitz Peek Hold Device/Lotek Dual A-Pillar Pod/AEM UEGO WB
sprigmo1 is offline   Reply With Quote
Old 11-13-2006, 04:39 PM   #2
sprigmo1
sprigmo1's Avatar
OK,
Upon further inspection, I took off top intercooler hose and accordian hose from turbo.
Oil puddled in front of turbo, accordian hose saturated with oil. Intercooler pipe has oil residue, but not pudlled in it like the accordian hose. Passenger side undercarriage saturated with oil. Catch can full of oil. Dipstick reads empty!
Old 11-15-2006, 12:00 AM   #3
sprigmo1
sprigmo1's Avatar
Upon further investigation, it seems most of the oil was pumped out of the engine, through the catchcan.
WTF????????????
Lot of oil in the turbo, accordian hose and intercooler piping!
So, it has to be coming passed the rings up through the head and out through the Catchcan, right???
I'll do the compression test this weekend. If it is the rings, does that mean new pistons and rings are needed.
Any reccomendations on rings /pistons. Aftermarket vs stock. JE, Wiseco, Ross etc....
Hopefully it is the turbo!
Old 11-15-2006, 03:32 AM   #4
jfunez
jfunez's Avatar
what if the turbo seals or the turbo oil feed lines are leaking, good to check that... maybe clean all of it out,fill with oil and start the engine and see where its coming from.... good luck
Old 11-19-2006, 08:46 PM   #5
sprigmo1
sprigmo1's Avatar
Default Compresssion Test
Did the compression test!
#1 Cyl. = 145psi
#2 Cyl. = 100psi
#3 Cyl. = 145psi
#4 Cyl. = 140psi
#5 Cyl. = 142psi
#6 Cyl. = 10psi
Well, Its either rebuild or part out!
My wife wants me to get rid of it, Of course I'd get rid of her first. But this has got to be the most depressing thing ever. Thought it was running great then......
Anyway, If I put it back together I still need to find out what caused the problem so it doesn't happen again.
Anybody got a line on some pistons/rings?
Home made Intercooler piping? mastergrader007 MKIII Supra 3 09-03-2008 06:37 AM
Why is this smoke coming from the turbo? Turbotuner2.3 MKIII Supra 3 11-12-2007 03:30 PM
Timing Belt Change, Do It at Home mrnickleye Supra FAQ 2 09-19-2006 06:24 AM
Oil n smoke from turbo wolfen Non-Generation Specific Questions 0 10-30-2005 12:27 AM
