Old 11-04-2006, 10:46 PM   #1
zcoolboard
zcoolboard is on a distinguished road
Default Coolant Leak
Ok so i have a coolant leak on my 88 supra. It is dripping down the transmission from the back of the engine i guess. the other day it was sputtering coolant up behind the head. i checked the hose that goes to the heater and the hose that goes from the head to the block and they seem fine.
i was wondering what part of the back of the head could be leaking. could it be any of the things in the picture?
p.s. the pictures are from an extra head i have, not the one i have on the car....obviously, haha
zcoolboard is offline   Reply With Quote
Old 11-05-2006, 09:31 PM   #2
zcoolboard
anybody have an idea?
Old 11-05-2006, 11:48 PM   #3
If it were mine.....
I would try to clean the area as best I could, to help see.
Then......
I would use a mirror and strong flashlight to see if its leaking at that fitting, or the hoses at the clamps, etc.
I suppose you'd need to get it hot to build up some coolant pressure, if you don't have a (access to a) pressure tester.
Old 11-06-2006, 04:38 PM   #4
Cool
you will probably find cracks on the hose that is connected directly behind the head but you won't be able to see them without the mirror like mrnickleye suggests
i'd plan on replacing it i don't know if your is a turbo but on the exhaust side of the block there is a rubber cap that could be leaking , it's located just below and just behind the turbo
. it's near the tranny but i don't think it would leak onto the tranny . just another thing to check . i'd say it's a cracked hose up top and behind
Old 11-06-2006, 04:49 PM   #5
Isphius
Isphius's Avatar
Yup, that cap leaked on mine. And those behind the head hoses leak all the time and are rather hard to get off. I just cut mine and then pried the clamp off the top of the fitting instead of the old fashion way of unscrewing it lol. But i wouldnt suggest doing that cause you can break the fitting off that way.
Old 11-08-2006, 04:30 AM   #6
jfunez
jfunez's Avatar
I think I got the answer....if its not that hose on the outlet...its the egr cooler cover gasket...that square cover on the back of the head...
If its a JDM engine without an egr. then there will be no cover but instead a coolant plug...check with a mirror and a light just as mr nickel eye sugests...
Old 03-29-2009, 11:33 PM   #7
Tazman3653
Tazman3653 is on a distinguished road
that square egr cover on the back of the head is not a coolant passage, no coolant should be in it at any time. it is a crossover port for the egr valve to send exhaust gas from one side of the head to the other.
Tazman3653 is offline   Reply With Quote
Old 03-30-2009, 06:54 PM   #8
Bill UK
AEM EMS
Bill UK's Avatar
Tazman 3653 is correct, most likely the union leaking or the hose connecting to it though. Check this out Link
Mysterious Coolant Leak Yoterman MKIII Supra 3 12-18-2006 03:30 PM
Strange Coolant Leak Help PLZ!! 87TurboProject MKIII Supra 11 03-14-2006 03:14 AM
MKIII coolant leak HELP sportriderseattle Non-Generation Specific Questions 2 12-21-2005 06:12 AM
