Old 11-08-2006, 02:30 AM   #11
j3pz
check the battery cables, check grounds... electrical problems are always a biotch
Old 11-08-2006, 08:04 AM   #12
west_side_supra
west_side_supra's Avatar
oh i know, electrical is my thing, after having to fix car toys problem with wireing my alarm and failing to ground it correctly, and basically catching my car on fire because of there shit. i had to rewire everything from my ignition to bassically all the wires on my fuse box but luckly i just so happen to have two of them mini fire extinguishers in the car if i didnt have that by by camaro
Old 11-08-2006, 09:51 AM   #13
f00g00
Default CB popping?
I didn't know there was a circuit breaker installed on the Supra but scince yours won't stay engaged then you have a short circuit. I havn't seen the scematic for it but you will have to repair the wire or not have power to the items on the circuit. Disconnecting the negative cable will not help reset this scince its the power after the breaker that has found a ground and is overloading the circuit when you try and reset it. Where exactly is the breaker?
Old 11-11-2006, 10:19 AM   #14
west_side_supra
http://www.cygnusx1.net/Supra/Librar...n=Main&Page=22
its the 2nd diagram, in your kick panel on the drivers side in the fuse box, its the far right one and its like the third from the top. it clicks on then off really fast. i hunted the ground wires for it down and it all looks good, didnt try to move them to a diffrent spot. its drivin me nuts though, why this have to happen when we get the worst rainy days ever. ERRR!
Old 11-11-2006, 10:25 AM   #15
west_side_supra
Getting Tipsy Yo
7MGTE - 500hp never dyno'd
fidenza cam gears
