Old 10-21-2006, 02:07 AM   #1
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Default Crankshaft work
Hi everyone, this is my first forum, so bear with me. I am about to rebuild a 7M-GTE and would like to know what Knife edging and Micropolishing is when it comes to cranks. And about how much would something like this cost?
abhattan is offline   Reply With Quote
Old 10-21-2006, 05:47 AM   #2
tone loc
tone loc's Avatar
sorry but what is that?
Old 10-22-2006, 01:46 AM   #3
WiseAssJester
WiseAssJester is on a distinguished road
I wouldn't do either unless you're expecting to attain some really high RPMs.
Prices? I dunno.Very dependant on the shop. Make sure you get a reputable shop.
WiseAssJester is offline   Reply With Quote
Old 10-22-2006, 03:45 AM   #4
rnoswal
rnoswal's Avatar
Knife edging is always helpful when it comes to windage in the oil pan. Not to mention the lightening wouldn't hurt either. Micro polishing will help the bearings last longer, but you may as well look for a coating on the bearings and pistons too. Use a synthetic oil, aluminum flywheel and it will be a fast revving engine for really quick shifting.
Russ
Old 10-22-2006, 04:07 AM   #5
tone loc
tone loc's Avatar
what is knief edging and mirco polishing?
Old 10-22-2006, 04:19 AM   #6
Murd
I don't know about micro polishing, but knife edging, they sharpen the counterweights on the crank to "cut" through the oil more efficiently.
Old 10-22-2006, 09:22 PM   #7
WiseAssJester
Knife edging and micropolishing ARE always helpfull.
However they are both very expensive around here.
Knife edging is dandy for high RPM and extreme horsepower setups, as I said. Very popular in the 60s and 70s, before they invented "technology." Haha.
I'd put a windage tray in it, that'll be plenty and its normally a lot cheaper.
Also, if you have it knife edged, you're gonna need to have your whole ensamble balanced, thats pistons, rods, clutch, flywheel so on, so forth.
There's a LOT of things you could do to get more benifit then the knife edging. Not that the knife edging wouldn't help, though for the record several sources aren't sure wheather the power is gained from the lightened crank or the knife edging its self.
There's a lot of nifty things you can do to help yourself out without breaking the bank. I'd reccommend a girdle, though that will get costly. And it doesn't increase power whatsoever.
It simple adds to durability.
Old 10-26-2006, 02:01 AM   #8
abhattan
abhattan's Avatar
Well, more than anything else, I am looking for durability at high RPM's and high boost/HP. And by high RPM's I mean about 7000-7500. Not really that high. And by high boost, I mean anywhere from 25psi-35psi. What is a wideage plate/cage?
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
crankshaft!!? ethan12510 MKIII Supra 6 04-07-2007 06:44 AM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
