Old 10-21-2006, 01:11 AM   #11
hangsupra
Originally Posted by Murd
One hot wire for tail lights, if the brake is on, then 2 hot wires. Unsure on color of wires however. Do your front marker lights come on? the yellow ones? If they do it's def. something in the back of the car, If they don't it's something in the front. Another thing, take your test light and make sure you're getting current to the fuse on the driverside kickpanel. The 15A fuse labeled tail, while the headlights are on of course.
the fuse on the driverside kick panel is good.. it lights up when i test it...
also at night.. i turn the headlight on... all the headlight up in the front comes on... even tho.. i turn the hazard aka turn signal on... it come on too... but for the back... i only got the brake while i step on the brake padel... and i only get the licese light come on at night when i turn the headlight on... and also the hazard/turn signal for the back only... beside this.. nothing on the back comes on...
ok i will work that on this weekend alright.. cause i dont have times at all.. but i try to get that done by this weekend tho... so yeah...
Tail Light Questions suprajsac MKIII Supra 3 12-13-2008 01:12 PM
Grounds for the left tail light supraman121 MKIII Supra 1 11-08-2007 12:57 AM
Tail light conversions..need help TargaMKII MKII Supra 8 02-28-2006 06:05 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
