Old 10-14-2006, 07:56 PM   #1
mad_dicer
mad_dicer is on a distinguished road
Default help with brake problem
i cant seem to get my brake lights to go out they are on all the time now
anybody know where the switch or what ever it is that switches the brake lights on when the brake peddle is pressed.
mad_dicer is offline   Reply With Quote
Old 10-14-2006, 10:10 PM   #2
dcrusupra
dcrusupra's Avatar
It's at the top of the brake pedal. It may not be a bad switch, but it could be the little round rubber piece that is on the pedal to push the button in on the switch. Thats what happened to mine. I ended up buying a new switch and it turned out to be the little round rubber piece that i sucked up with the vacuum a few days earlier.
New Rebuild
My CarDomain
Old 10-16-2006, 12:52 AM   #3
mad_dicer
most likely what happened here switch is still good and no rubber piece on the peddle but i just adjusted it closer to the peddle and it works again.
Old 10-17-2006, 12:23 AM   #4
hangsupra
you mean the brake-light under the dash-board or the back tail-light...
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
Help!! major brake problem.... bigal0043 MKIII Supra 18 04-15-2006 05:29 PM
brake lights problem MWoz34 MKIII Supra 2 09-14-2005 03:08 AM
