Old 10-13-2006, 06:21 AM   #1
sd88supra
sd88supra is on a distinguished road
Default gas hatch not opening
my gas hatch wont open! I was wondering where the opening mechanism is exactly.
sd88supra is offline   Reply With Quote
Old 10-13-2006, 08:29 AM   #2
Isphius
Isphius's Avatar
There is a cable running along the driver side floor. These are prone to breakage. You can just leave it "unlockked" all the time like i did. If you go on the passener side of the trunk/hatch, There is a little panel you can pull off. From here you can reach over by the gas tank lid, And feel the hatch clicker/lock thing. You have to cut the cable and pull it to get it to open(or find the place where its broken, Mine was right by the inside handle), Then once open, take the nut off from inside the gas cap area, And pull the clicker out. Then your gas door will be accessible all the time, Untill you buy a new cable, But at least you can buy gas now. I even passed inspection NJ with that, If it matters
Old 10-13-2006, 08:23 PM   #3
tone loc
tone loc's Avatar
our pump the lever while someone trys to pry it open with there fingers or screwdriver but use like a towel or something so you dont scracth the paint.
Old 10-14-2006, 12:37 AM   #4
Isphius
Isphius's Avatar
Well if the cable breaks the thing is basically locked closed. But if its just loose, then that will work. Give it a try and post back.
Old 10-14-2006, 04:12 AM   #5
sd88supra
i guess my cables is only loose. its not broken, at least not yet. i just played with the lever on the inside until it popped out. i think the pusher thing inside the hatch was loose too, cuz i tightened it and it opens easier now. still, im gonna look into fixing the cable so it doesnt come as a surprise later on. in the meantime i filled my tank
Hood & Hatch Supports mrnickleye MKIII FAQ 2 04-16-2009 01:37 PM
Rear Hatch Won't Open-HELP! Benesesso MKIII Supra 4 07-21-2008 12:37 PM
Fighting the Dreaded Leaky Hatch Lunch2000 Non-Generation Specific Questions 12 08-27-2006 10:08 PM
Hatch Problems AZN_Pride MKIII Supra 6 07-27-2006 03:56 AM
