Old 10-11-2006, 03:19 AM   #1
h8z2luze
h8z2luze's Avatar
Default Whinning????
I dunno if its a common noise for these supras but when I accelerate I hear a whinning like the cams maybe it almost sound like turbo but steady. I am guessing its the cams doing it. Whatever it is sounds cool lol. Any thoughts?
Old 10-11-2006, 04:18 AM   #2
dcrusupra
dcrusupra's Avatar
Check your trans fluid.
New Rebuild
My CarDomain
Old 10-11-2006, 06:27 AM   #3
sounds like your turbo has gone ka bluey
take off your intake and check the compressor wheel, make sure all fins/blades are still there and if it has any side to side or back n forth play
Old 10-12-2006, 05:40 AM   #4
h8z2luze
h8z2luze's Avatar
lol its a n/t And its a 5 speed...
Old 10-12-2006, 06:17 AM   #5
well i guess that screws that theory then LOL
Old 10-12-2006, 06:20 AM   #6
dcrusupra
dcrusupra's Avatar
Does it happen in any certain gear? Or is it an all time thing?
New Rebuild
My CarDomain
Old 10-12-2006, 11:52 PM   #7
h8z2luze
h8z2luze's Avatar
all the time. But seems louder in 1st.
Old 10-13-2006, 12:01 AM   #8
nelly26
nelly26 is on a distinguished road
Cool
how is clutch release bearings i have same mine clutch needs replacing push clutch pedal and see if it is still making a noise
nelly26 is offline   Reply With Quote
Old 10-13-2006, 12:06 AM   #9
rnoswal
rnoswal's Avatar
Sounds expensive! LIke the earlier post, check your trans fluid. Cams should be completely quiet, but it could be an excessory like you Oxy pump or powersteering pump. It could even be something rubbing against your flywheel. Maybe someone put playing cards on your spokes......;-}.
The point being, it should not whine or complain unless it needs some attention somewhere.
Russ
Old 10-13-2006, 12:18 AM   #10
dcrusupra
dcrusupra's Avatar
My trans used to whine like crazy in second gear. Later, when I was taking out my engine, I tried to drain the trans and there was absolutely no fluid in it.
New Rebuild
My CarDomain
