Old 10-13-2006, 02:15 PM   #11
supra1985turbo
supra1985turbo is on a distinguished road
Okay you might have to take the cross member out I have not recieved my ma70 yet so I could not look under the car thanks for the picks. But there is not that much difference between the mkii and the mkiii my rack inpinion is on the back side of the cross member and the cross member is flipped the other way. is the oil pan sump above the cross member or is it in front of it. rasing the engine will still give about two inches of play.
1985 celica supra upgrading to street/drag well mainly drag. Have complete HKS T4 turbo kit, electronics and all, Getting head port and polish with HKS 264 cams, and port and polished intake with 6 extra injector bungs. Eagle or crower rods? I just bought a 1990 MA70 n/a .
supra1985turbo is offline   Reply With Quote
Old 10-14-2006, 04:52 AM   #12
burton51m
burton51m's Avatar
Originally Posted by rnoswal
If you do pull the engine, you might as well replace all the seals and gaskets, which in the long run would be best, but for the pan, pull the crossmember.
Russ
i just recently got a BHG so the gaskets n seals are gonna be replaced (most of them).
whats weird is the engine was remanufactured around 100,000 miles so my headgasket shouldnt have gone so early.
hks head gasket suprabahamut MKIII Supra 8 09-01-2007 04:28 AM
head gasket suprabahamut Non-Generation Specific Questions 1 05-04-2007 04:13 AM
gasket help hangsupra MKIII Supra 14 01-28-2007 05:35 PM
