Old 03-21-2007, 09:56 PM   #11
j3pz
thats for an automatic, right? goes through the whole where the clutch pedal/ master cylinder would be. i had a friend install mine, drilled a hole where there was nothing on both sides, and put in a gromet. i dont have a pic, you just dont to get in there look and feel around
Old 03-21-2007, 10:52 PM   #12
V1P3R
V1P3R is on a distinguished road
Originally Posted by burton51m
http://i8.photobucket.com/albums/a8/...g?t=1174508756
http://i8.photobucket.com/albums/a8/...g?t=1174508784
This is where i drilled. You can see where it came out in the engine bay. It's 4 gauge wire going from my battery to my trunk.
Hey thanks man, but when I just checked mine is set up differently being a 1989, that top left corner of the engine bay doesnt look like yours
Im not too great with cars, there is a resavoir where you drilled your whole through, im guessing clutch fluid since mine is standard transmission?
I cant seem to find ANY holes in the firewell or any space ANYWHERE to even attempt a hole.
This is killing me, I definitely dont want to drill in the wrong spot but I cant even find a spot TO drill!
V1P3R is offline   Reply With Quote
Old 03-22-2007, 02:40 AM   #13
burton51m
burton51m's Avatar
I drilled mine in the top right if you were standing in front of the car as the viewpoint. It shouldnt be that different.
Old 03-22-2007, 05:53 AM   #14
V1P3R
Yeah now I see, but where your hole is drilled there is a cable/hose leading to a resevoir mounted there with dark fluid inside. Small resevoir, im guessing its clutch fluid possibly? Sorry for being such a greenhorn!
Old 03-22-2007, 02:50 PM   #15
j3pz
yes thats were the clutch master cylinder is. my whole was lower, under the steering linkage. if i can get a pic today i will.
Old 03-22-2007, 07:32 PM   #16
V1P3R
How did you find any space down there? And where does it go through on the other side? A pic would be AWESOME!
Old 03-22-2007, 08:44 PM   #17
redmaro
Ill post the a pic for you later.
MK3, Auto, Turbo.
Old 03-27-2007, 09:31 PM   #18
V1P3R
Any luck getting a pic?
I need to figure out how to wire the power wire for a Manual/5spd not Automatic, unless the Automatic is wired somewhere where the difference in transmission wont affect the location.
Thanks in advance to ANYONE who can help me out here!!
Old 03-29-2007, 12:06 AM   #19
j3pz
i got pics, ill post them when i get home.
Old 03-29-2007, 12:56 AM   #20
j3pz
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
