Old 10-06-2006, 06:53 AM   #11
a) brand new doesn't matter, you may have put a clamp on crooked
but since this is only when it's hot (by which i assume you mean up to temperature not overheating)
check the tsrm with a voltmeter and go thru the checks for your air flow meter
it is more than likely a worn/broken/shorting wire in your engine harness not in the afm itself if it does it with a good afm also
Old 10-06-2006, 06:55 AM   #12
bigdoggbmx
bigdoggbmx's Avatar
bigdoggbmx is on a distinguished road
Default question
when this happens the smoke is not that bad and why does it only do this when it gets hot it does not do this when the car is cold at all it runs fine great grand
what could this beeeeeeeeeee i realy do not think that it is a boost leak it has got to be somthing else is there any thing else that it could be
bigdoggbmx is offline   Reply With Quote
Old 10-06-2006, 06:56 AM   #13
bigdoggbmx
bigdoggbmx's Avatar
Default q
i also checked over all the wireing and fixed all the cracked wire
Old 10-06-2006, 07:00 AM   #14
bigdoggbmx
bigdoggbmx's Avatar
Default q
this car of mine i have had nothing but problems with it
should i call it quits or keep on pumping more money in it it has a new motor and it is in pretty good condition
Old 10-06-2006, 07:02 AM   #15
mk111boy
mk111boy is on a distinguished road
could the greddy bov valve be leaking the boost
mk111boy is offline   Reply With Quote
Old 10-06-2006, 07:06 AM   #16
bigdoggbmx
bigdoggbmx's Avatar
this is prob a dumb question what is trsm
Old 10-06-2006, 07:11 AM   #17
the link i posted before
get your multimeter and do the checks it tells you to
tsrm = the online repair manual for the supra
please do the checks before you come back and post as we need to know the results
Old 10-06-2006, 07:13 AM   #18
bigdoggbmx
bigdoggbmx's Avatar
i have the book on this and it pulls a 31 code
Old 10-06-2006, 07:14 AM   #19
bigdoggbmx
bigdoggbmx's Avatar
so this tells us that it is the air flow meater and this is not the case this stupis ass car has had this replaced 3 time and still the same results this is kinda odddddd dont ya think
Old 10-06-2006, 07:16 AM   #20
ok sorry to sound harsh but
read the damn link
it tells you to test your ecu and wires to determine where your problem is
no where does it say only your afm is bad
