Old 10-01-2006, 07:58 PM   #1
supraman121
Exclamation Broken spark plug! HELP!
Today i was changing the spark plugs and i took the last one out or tryed and i got the spark plug it self and the hex nut but the hex nut broke off at the threads leaving the lower half of the plug in the engine!!! If someone could tell me a tool that i could use to get it out i would be for ever greatful, Or tell me how much work it would be to do myself,(How much will this cost to have someone take it out for me)
Thanks
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 10-02-2006, 04:38 AM   #2
mrnickleye
mrnickleye's Avatar
I've sen a lot of weird shit happen on cars, but not your problem.
If it were mine (n/a motor), I would bring the cylinder up to TDC (using the distributor to make sure). Then I would use a punch & hammer to knock out(into the engine) the ceramic that remains.
Then I would use an 'easy out' to remove the remaining threaded part from the head.
There are several kinds of removers. I would 'try' the common one first, as it is the cheapest. DON'T turn it so hard that IT breaks off inside, as you will never get that out.
Also, soak the parts with WD40 real good for a couple hrs before starting. Do this now !
Old 10-02-2006, 08:40 PM   #3
supraman121
i was getting the alarmed dissconnected and i asked the auto place to see what they could to they said it wasnt any big deal they could get it out... they didnt give me a quote but i told them to do it. With the alarm dissconnection and the spark plug taken out it cost me 200 bucks and they change them for me put in my bosch platnum 2's in so it works great. But told me i needed to get the intake manifold and the throttle body cleaned badly and i need a new set of wires.
That's what happenes when no one takes care of a car. lol (it wasnt me i just bought it) lol
K&N Air Filter
Spark plug wires Quik Q carfanatic89 MKIII Supra 2 05-22-2008 01:46 PM
spark plug wire WARNING! cars4me89 MKIII Supra 1 08-12-2006 06:24 AM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
Spark plug leads for 1g ekoston69 MKIII Supra 0 12-30-2005 03:18 AM
stripped spark plug *c-town* MKIII Supra 3 12-20-2005 03:27 AM
