Old 09-12-2006, 05:51 AM   #1
uddinf
uddinf is on a distinguished road
Default engine cuts and dies
hello, I have been reading the forum for a while and hate to make my first post with one of these problem questions but I'm in need of some help.
I seem to be having an issue with my 1989 mkIII Turbo. As I am driving, if I accelerate and get the rpm's to rise quickly and then depress the clutch, the engine will cut out if I let the rpm's fall back down to idle and not shift into another gear. In some cases when the car approaches idle the check engine light comes on for a breif second and if I see the light I usually press the gas a bit to prevent the car from dieing. If the engine dies, however, all the car electrronics and (radio and ventilation) are still working but the power steering does not work and the steering is stiff and the dash will display the battery warning light. Whenever this happens I re-ignite the engine and it starts without any issues.
Has anyone experienced this or know what I should be checking? Also, woud checking engine diagnostic codes be a useful idea?
Thanks in advance
uddinf is offline   Reply With Quote
Old 09-12-2006, 06:17 AM   #2
mrnickleye
mrnickleye's Avatar
The engine is dieing. Check for stored codes. (see FAQs section for instructions how).
Possilbe TPS.
Old 09-12-2006, 08:30 PM   #3
uddinf
any reason that makes you think that the engine is dieing and at the end of its life? is this a common symptom for engines that will soon require replacement?
Old 09-12-2006, 11:03 PM   #4
jfunez
jfunez's Avatar
Possilbe TPS.
he ment dyeing as in stalling or cuting off, not as in its last leg or completely dye as in for ever.
Old 08-20-2009, 04:37 AM   #5
top-tuner
top-tuner is on a distinguished road
Default top-tuner
Hi Guys,
I am also new here......
So greetings to all....!!!!
Does anyone know the values for coolant and intake air
temp sensors in volts for hot and cold ????
My engine is a 2JZGTE twin turbo 3 liter..
GRT,
top-tuner is offline   Reply With Quote
Old 09-02-2009, 12:13 AM   #6
Triggarise
Triggarise's Avatar
Triggarise is on a distinguished road
Thanks in advance
I also have this problem in my mk3 87 Turbo. same EXACT problem. so if you guys could finally solve this mystery once and for all! it would be awesome... side note: i have an aftermarket BOV HKS SS. i just unplugged the vacuum from the stock one and hooked it to the aftermarket one. however my car had this issue before..
Triggarise is offline   Reply With Quote
Old 09-02-2009, 06:40 AM   #7
top-tuner
Default top-tuner
Well as you mentioned that the engine has an aftermarket
B.O.V vented outside the engine will get overfueled as
the B.O.V releases the exessive air !!!!
Does your engine have a M.A.F sensor ???
The only way to fix this is to recirle the B.O.V air back in the
intake tube by the air filter .
Or what i did is buy a P.C.V valve with 5/16 inch barb fitting
and put this inline with the vacuum line from the intake manifold
it helps a lot a the engine will no longer cut out .
GRT...
Old 09-04-2009, 04:59 AM   #8
Triggarise
Triggarise's Avatar
GRT...
is there a step by step for this? im a little confused still
Old 09-06-2009, 04:44 AM   #9
CodyTT
CodyTT is on a distinguished road
It could maybe be your oil pressure is too low?
CodyTT is offline   Reply With Quote
Old 09-06-2009, 06:56 AM   #10
Triggarise
Triggarise's Avatar
i do have leaky valve covers. i dont know how to fix them =[
