Old 09-18-2006, 03:13 AM   #21
supra90turbo
supra90turbo's Avatar
supra90turbo is on a distinguished road
All cars are different. Fuel cut occurs at different points, at different times.
I had a religious fuel cut at 15psi exactly.
I tuned my ProfecB specII to hold a rock solid 14.7psi and it never hit fuel cut.
supra90turbo is offline   Reply With Quote
Old 09-18-2006, 04:24 AM   #22
Isphius
Isphius's Avatar
Oh thats pretty good then. Ive head most are around 11-12 thou, although i guess some could be higher.
Old 09-18-2006, 08:19 AM   #23
Supra2NR
Supra2NR's Avatar
well
he's from MA
your from NJ
im from chicago
cold states in here
kinda make the bitter cold of the winter time seem a lot better
Old 09-18-2006, 11:35 AM   #24
Isphius
Isphius's Avatar
Haha yeah it gets pretty dam cold here. I deleted your post cause it was a double so no hard feelings haha. How is chicago?
Old 09-19-2006, 03:17 AM   #25
Supra2NR
Supra2NR's Avatar
no problems, its sumtimes my computer f's up thats what happens
so it'll a favor to me and everybody if u deleted it lol
but maaaan, it jus the middle of september and the wind chill is about 40- 50 degrees already
the winter could be so much better, without the damn wind
it could be 35d's outside
but thanx to the windchill, it can feel like 10 degrees outside
well, thats what i get for living in the windy city, so no one to blame here lol
but only pple in chicago can do this
and you will only hear and see this in chicago
in the middle of the winter time, when the regular temp is about 20 - 35 degrees
if it warms up to 45 degrees , that already warm enough for chicago pple
you will see pple walking outside with a t-shirt in the middle of winter
but in the summer, when the temp is about 90 degrees,
if it cools down to 60, pple feel like theyre gonna die from the cold
and the coats come out in the middle of summer
i guess pple jus get use to the weather too quickly here lol
Old 09-19-2006, 12:40 PM   #26
supra90turbo
Mine was regardless of weather.
100* out and 70% humidity, 14.7psi
40* out and 0% humidity, 14.7psi
MA gets a large variety of weather ranging from extreme heat and humidity to extreme cold.
Old 09-20-2006, 12:15 AM   #27
Supra2NR
Supra2NR's Avatar
but back to the questions
what happens when you hit fuel cut?
and whats the worst that can happen if you hit fuel cut?
and what's the highest boost that the engine can take?
whats the highest boost that pple have had in the 7mgte engine?
Shimming Wastegate Poodles MKIII Supra 22 03-08-2010 06:46 PM
External Wastegate! teedoff00 MKIII Supra 1 04-11-2007 03:49 AM
Wastegate? drmmr15 MKIII Supra 19 01-16-2007 07:07 PM
