Old 03-31-2005, 03:17 AM   #1
mdrury916
mdrury916 is on a distinguished road
Is there any other reason besides head gasket that would cause this? I am having the compression test done in a day or two, but it is driving me crazy waiting on my mechanic to do this, and give me the results.
I just bought the car, and seem to have a lot of the common problems that everyone else has. It is a very clean 89' turbo with 82k miles on it.
The reason that I am asking, the car has a 1.5mm MHG and port/polished head done on 7/26/04, and only 5k miles since then. If too much boost will blow a gasket, then that is what happend. He had the manual boost set @ 20psi!!!!!
I have dissconnected the manual boost control, and going to install an electronic one after I fix the water problem.
Michael
mdrury916 is offline   Reply With Quote
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
