Old 08-03-2006, 04:23 PM   #1
tone loc
tone loc's Avatar
Default help! white smoke out tail pipe
i changed my oil yesterday and when i started my car today white smoke started pouring out my tail pipe and it smells but that could be because my car is in the garage.(garage door was open) Can someone tell me what the problem could be and what should i do to fix it? Thanks
Old 08-03-2006, 04:31 PM   #2
tone loc
tone loc's Avatar
how do u check oil level? u have to run the car a little then turn off engine wait a few minutes then check right? If thats how u do it then the oil level is perfect.
Old 08-03-2006, 06:09 PM   #3
tone loc
tone loc's Avatar
i dont think i could have a bhg because i didnt drive it since i bought it and it was just fine. The only time i drove it was in and out of my driveway.
Old 08-03-2006, 09:56 PM   #4
theWeezL
theWeezL's Avatar
White smoke (more like steam and has a sweet smell?) bluish white smoke (acrid oder, smells like burning oil?) or Black smoke (smells like gasoline?)...and its coming right out of the tailpipe? or is it possibly burning off the engine somwhere? (maybe you spilled some oil when you were changing it?)
Also recheck your fluids, make sure your oil is amber and your coolant is green (or orange if you use that kind). If your fluids are ok, let it idle and reach normal operating temp. Watch it closely, look for the source of an leaking fluids. Watch the temperature gauge, and pay attention to any funny noises or anything out of the ordinary.
Let us know what you find out.
____________
Old 08-04-2006, 04:26 AM   #5
marc
rule or smokes..black is gas...blue is oil and white is coolant. u prob have a coolant leak sumwhere. the coolant is getting burnt and comming out of ur exhaust
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 08-04-2006, 10:29 PM   #6
Isphius
Isphius's Avatar
Just let it idle a while and see if it goes away. Sometimes that happens when you change the oil. It can pool and get sucked in through the PCV system. Try running with the oil cap off and see if smoke comes out of the oil cap. If it does, Thats bad. And check to see if the coolant is getting burned. The smells of car fluids are all very distinct, but they are hard to describe. Do like supran2r said and give it a smell. Antifreeze you cna taste and smell, its sweet and smells like an old gym locker kinda. Power steering or Trans fluid smells kinda like carrot juice/ass. Oil just smells like burning...oil. You should be able to tell. And there is pretty much nothing else that could be burning through the motor.
White smoke from exhaust manifold Rommy MKIII Supra 15 07-26-2009 06:32 PM
White Smoke Drag0na5h MKIII Supra 1 04-25-2006 06:36 AM
NEED HELP...Does white smoke = BHG? 87sleeper MKIII Supra 10 01-11-2006 12:38 AM
White Smoke at Startup Makavelli MKIII Supra 5 07-29-2005 02:45 PM
white smoke steve119md MKIII Supra 5 05-24-2005 08:57 PM
