Old 07-29-2006, 09:40 PM   #11
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
check your gounds
this is why the car won't go!
the two earths on the intake manifold are the grounds for the ecu
check your grounds!
Pics of my build.
Do a diagnostic first!
Old 07-29-2006, 10:58 PM   #12
Isphius
Isphius's Avatar
There is a way to test your ecu by measuring its resistance, I dont know what part it will check out tho. But generally if the resistance of any electrical component is different than factory, Its a good idea to replace it. Look in the tsrm. And yes, Def check all your grounds. Bad ground = Bad stuff.
Old 07-30-2006, 05:41 PM   #13
Toyota87Supra
Toyota87Supra's Avatar
Toyota87Supra is on a distinguished road
It was a blown fuse so to my EFI but now that it is fixed my car starts right up but it is still having trouble running. I know there is something messed up with my TPS because it idles at 500 rpm but i am still getting a rich fuel mixture which leads me to believe my Mass air Meter is dead too. I checked the codes again and got 51 and 31 I need to know if there is anything i should do before buying a new TPS and MAF.
Toyota87Supra is offline   Reply With Quote
Old 07-31-2006, 06:06 AM   #14
1988gte
1988gte is on a distinguished road
Originally Posted by suprra_girl
check your gounds
check your grounds!
agreed been there done that, fixed broken ground and idled just right after
1988gte is offline   Reply With Quote
Old 07-31-2006, 06:22 AM   #15
suprra_girl
7M POWAH! ;)
code 31
Air Flow Meter Signal
(7M-GE)
Open circuit in VC signal or short circuit between VS and E2 when idle contacts are closed.
(7M-GTE)
Open or short circuit in air flow meter signal.
Air flow meter circuit
Air flow meter
ECU
http://cygnusx1.net/supra/library/TSRM/fi/FI_038.html
code 51
Switch condition signal
No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Check to to make sure you were in Park or neutral when doing the diagnostic and also check to make sure a/c wasn't switched on when doing the diagnostic
try another air flow meter
and you haven't said if you have fixed your grounds
Pics of my build.
Old 07-31-2006, 06:29 AM   #16
Supra2NR
Supra2NR's Avatar
jus listen to the girl she knows what shes talking about
jus fix the ground
and if that doesnt work
consider a licensed professional
Old 07-31-2006, 02:52 PM   #17
Isphius
Isphius's Avatar
Well i would assume he now fixed the elctrical problem becasue the car starts, And is now trying to fix the bad running problem. But yes the ground wires are probably what caused the code 11 in the first place. I think it would be fine now that its giving him real codes.
Old 08-02-2006, 08:26 AM   #18
Toyota87Supra
Yes the grounds are good now im just gunna replace the MAf And TPS and see what happens.
Old 08-02-2006, 08:29 AM   #19
suprra_girl
7M POWAH! ;)
just do the afm (not maf on ours)
Pics of my build.
