Old 07-20-2006, 01:43 PM   #1
junkyard supra
junkyard supra is on a distinguished road
Default junkyard swap
hello all, i have a few questions about a swap that im trying to do in a junkyard (lots of fun) , i have 3 supras to work with , 1.. 7-mgte,manual, yellow plugs (totaled in front) 2.. 7-mgte,auto, grey plugs.. and 3, 7-mge,manual, yellow plugs. ok my problem is the motor i have to use is the one with the grey plugs, but i have an auto ecu. im trying to see if i can swap out just the plugs themselves or is it possible to use the yellow harness on the other motor? the reason why this is important is b/c i have an hks f-con and fuel cut defender but it is all for the yellow plugs.. PLEASE help!!, i really want to use that f-con and fuel cut all help is greatly appreciated
junkyard supra is offline   Reply With Quote
Old 07-20-2006, 03:03 PM   #2
tone loc
tone loc's Avatar
so ur going to use an auto 7mgte and you want to make it manual transmission or just change plugs?
Old 07-20-2006, 04:57 PM   #3
junkyard supra
yes i am using a manual, but its a newer 7-mgte with the grey plugs. the f-con and fuel cut are from a older one, i want to be able to use the f-con and fuel cut defender so is it possible to cut the ecu plugs and swap them out so i can use the yellow ones?
Old 07-21-2006, 06:33 PM   #4
junkyard supra
anyone know if the wiring is the same in the grey plugs and yellow plugs? i would much rather cut the plugs than re-wire the whole motor
1jz swap 87-POSupra MKIII Supra 4 10-27-2008 03:34 PM
JDM swap, now engine light, please help christutecky MKIII Supra 0 08-10-2007 07:49 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
2JZ Motor Swap MDellboy420 MKIII Supra 3 09-11-2006 06:19 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
