Old 07-21-2006, 09:34 PM   #11
Isphius
Isphius's Avatar
Ok i fixed the brake lights, but now i have a more serious problem. When I hit my brakes, My climate control panel flickers or goes out. And going down the highway, If i put the heat to off, It Makes the red batterty light go on, The brake light go on (dimly/flickering), And the voltage go up to almost 18 or less if i let off the gas. and when i switch it between high and off it causes the car to just die altogether for 3 or 4 minutes at a time. This is not good when your in 80 mph traffic and all your lights and motor die and your in the middle lane. To say the least, Im severly pissed at my car ATM, And i dont even feel like going out to look at it. It died at least 10 times on my way home. But when not on the highway, It seems fine. Except the CC buttons still flicker when i hit the brakes, But the car doesnt die. I seriously need some help with this, I dont know much about the supra wiring or what could even cause this. Its like the heater can just...disconnect the battery cable. BTW all fuses are intact, The cables are on tight, And the battery is a 2 month old 250$ gell battery. Any help appreciated
Old 07-21-2006, 11:01 PM   #12
dcrusupra
dcrusupra's Avatar
Bad or loose ground wire somewhere? What was wrong with the taillights?
New Rebuild
My CarDomain
Old 07-21-2006, 11:11 PM   #13
SupraSaver87
SupraSaver87's Avatar
SupraSaver87 is on a distinguished road
Default Possibly bad, maybe good
Well the sounds of it you have two wires touching somehwere...maybe a wire snapped out of its holder, and managed to touch another one. <---- that is highly unlikely, but still a possibility.
If it isn't that then there is always the fact that your electrical system is now dying. I hope not, because I just look at the wireing harness and don't want to touch it....I am not good with electrical stuff. (Makes me think back to when I shocked myself, and woke up on the other part of the room)
My Ride: http://www.cardomain.com/ride/2351563
Our Supra’s, which art in the driveway,
Hollowed be thy power, thy mods are great, thy speed endless,
On the road or at the track. Give us this day free of cops,
And forgive us our impound charges, as we forgive those who are slow.
And lead us not into speed traps, and deliver us from the interceptors,
For thine is our car, the power, and the glory…forever and ever….amen.
SupraSaver87 is offline   Reply With Quote
Old 07-21-2006, 11:47 PM   #14
Isphius
Isphius's Avatar
Well i just drove an hour an a half home, And it didnt. It might have been cause the car was hot and losing a soldering connection or something. It still does the flickery thing thou.
Old 07-21-2006, 11:55 PM   #15
theWeezL
theWeezL's Avatar
definately a short somewhere, which can be a real pain to find. I would recommend pulling some access panels, maybe even the gauge cluster...then wait till its dark out (or do this in a garage where you can get it dark enough) and then try turning on the CC and/or other things while looking for a faint spark. you can wiggle some wires back there too to try to duplicate the problem or even possibly alleviate it.
The only thing that has me concerned is that if you have a short and its not blowing a fuse...then the wire thats shorted is a direct connection (meaning pre fuse block) and that can be a little scary...if you've ever seen a wire fire in a car....trust me you dont want that to happen!
____________
Old 07-23-2006, 05:38 AM   #16
Isphius
Isphius's Avatar
Lol, well my monte carlo, before doing a remote starter solenoid and heat shield, The header would melt the starter to the "ON" position, Even if the key was completely off and out of the car. I remember my dad telling me to stop cranking and i was holding the key out the window and he was like man that s not good. Anyways competely melted the entire wiring harness that goes to the starter/trans and the battery exploded all over and corroed my paint to hell. So Ive got a little experience with that haha. But, I think it has something to do with a short inside the control panel. Because when it flickers, I noticed in the dark, Its becasue its going to night mode and then day mode fast, Like dim/all lights on, to not dim/lcd/button lights only. And its got something to do with the brake switch. Because that is what i adjusted to fix the lights. Thansks for the replies all...wish me luck
Old 09-07-2009, 08:48 PM   #17
sbualuba
sbualuba is on a distinguished road
How did you fix the tails from staying on... I have the same problem
sbualuba is offline   Reply With Quote
Brake Lights zebrahabitz MKIII Supra 2 08-13-2009 06:29 AM
Brake lights not working! lifesnotfair MKIII Supra 18 05-05-2008 11:40 PM
Brake Lights? bpalmer21 MKIV Supra 2 07-23-2006 04:15 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
brake lights problem MWoz34 MKIII Supra 2 09-14-2005 03:08 AM
