Old 07-08-2006, 06:37 PM   #1
mankatosupra
mankatosupra is on a distinguished road
Default wierd oil leak
just looking for some suggestions. just finished the dreaded bhg job, went to start her up, and i have oil flooding from the front of the 1st cam bearing retainer cap(the one that is up front, outside of the valve cover, behind the cam gear.) i took everything apart and double checked torques etc. and it still does it. obviouosly there is no gasket there, should i try a high temp sealant under the cam bearing retainer?
mankatosupra is offline   Reply With Quote
Old 07-08-2006, 10:17 PM   #2
mankatosupra
Default im dumb sometimes.
nevermind, im retarded. just found the seals.
Old 07-08-2006, 11:54 PM   #3
supra90turbo
supra90turbo's Avatar
glad you fixed it, but you forgot to put the cam seals in?
Oil Leak. supramacist MKIII Supra 0 05-01-2008 01:18 AM
Coolant Leak bossman MKIII Supra 2 04-12-2008 09:31 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
