Old 06-28-2006, 07:12 PM   #1
black_knock313
black_knock313 is on a distinguished road
Default just bought supra
i just bought a 1987 supra turbo i dont know much about them all i know is i love ther look and power so i bought it with a motor knock on the bottom end of the 5th cylender and im not sure what i should do buy new or rebuild and repair it ne help would be really apreciated
ty nick
black_knock313 is offline   Reply With Quote
Old 06-29-2006, 07:30 AM   #2
Isphius
Isphius's Avatar
If you dont need to drive the car right away....Pull the motor, And have the crank and rods checked out by a shop or get a digital micrometer and a repair manual and do it yourself. If its rebuildable (not driven long with the knock) Get a rebuild Kit. They have em for under 1000 with pistons, bearings, gasket set, oil pump and timing belt. Then you should take the head to get a valve job done and the seals replaced. Which i think i got a quote for 250 on. So for about ~~~1100$ you have a brand new engine, internally. And if your goin that far, Get a metal head gasket and ARP head studs and have the block and head machined perfectly flat. Then youll have a serious motor.
Old 06-29-2006, 07:33 AM   #3
Isphius
Isphius's Avatar
Plus youll most likely need to have the crank turned because it almost definatley has a spun bearing. Most machine shops can do this pretty cheap
Just bought my first Toyota Supra MKIII turbo 1989 Power=Speed Non-Generation Specific Questions 1 11-02-2008 12:51 PM
bought a 93 supra steve7o2 MKIV Supra 2 10-05-2008 03:45 PM
1986.5 Supra, Just bought this afternoon. MeatRo MKIII Supra 6 09-07-2007 06:38 AM
Im new here.. just bought an 88 na supra Gee-oob MKIII Supra 5 09-30-2005 12:21 AM
