Old 07-16-2006, 04:23 AM   #1
marc
whats the default timing on an 88 supra thats stock. and whats a good adjustment for it. im ganan be adjusting my timing in the next 2 days so any opinions would be appreciated.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 07-16-2006, 05:07 AM   #2
kwnate
SP58GT
10*, a good adjustment would be 10*
Nate
Old 07-16-2006, 06:02 AM   #3
marc
wait ur sayin the stock is 10? and i shuldnt adjust it?
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 07-16-2006, 08:47 PM   #4
marc
cmon ppl..inputs plz. wats a good adjustment to set an 88 supra too?
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 07-16-2006, 09:09 PM   #5
supradaddy0803
supradaddy0803's Avatar
Default ok here you go
This is straight out of the toyota shop manual 10 degrees before top dead center. While shorting out the T and E1 pins on the check engine connector or else you will get a spark advance.so he told you right 10 degrees is a good bet. Just remember before you time it short those pins or you wont get it right at all. If that doesnt help you probably got a problem with you spark advance inside your distributor then you will have to check the air gap on the Ne, G1, and G2 positions if they are off it will knock off your timeing as well. the gap should be .008 - .016 of an inch or .2 - .4 mm if you like metric.
Old 10-31-2006, 02:02 PM   #6
SupraDupra
SupraDupra's Avatar
The way I am reading that is basicaly ,you can't adjust the advance from the distributor because timing is computer controlled? Is that why everyone uses cam gears to adjust timing?
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
