Old 06-24-2006, 06:23 PM   #1
theWeezL
theWeezL's Avatar
86 or 86.5? Im assuming 86.5 since you posted in the mk3 forum. So going on that assumption....
The least expensive and easiest thing to do for the BHG is to get a quality stock replacement gasket (by quality I mean a good brand) and a set of ARP head bolts. Clean your parts well when doing this. Use chemical cleaners on the head to remove the residue of the old gasket because scratching it with a scraper is a real bad deal. I would recommend since you already have the head off, having it rebuilt anyways but you dont have to. It kinda depends on if you want to do this job again sometime down the road. Put it all back together and torque the head bolts properly (in sequence and in stages) to...I'm unsure of the spec on ARP bolts but I know the stock ones can take 75lbs...someone else here know the torque specs for ARP?
If you follow that you should pretty much be safe from ever having a BHG again.
____________
Old 06-24-2006, 10:55 PM   #2
"sharp"
"sharp" is on a distinguished road
yeah its and 86.5. I was thinking the same thing about rebuilding it while i had it all apart. so any idea on what this is going to cost or how much time i will need to complete the job? just replacing the gasget not with the rebuild.
"sharp" is offline   Reply With Quote
Old 06-24-2006, 11:42 PM   #3
stumpjumper
stumpjumper is on a distinguished road
$100 for the arp bolts
$2-300 for the cylinder head rebuild and milled
$75-120 for the gasket set
so roughly $500. Good time to replace the spark plugs, timing belt and the cooling system including the heater hoses in the rear of the engine bay.
Labor is about 6-12 hours depending on skill level.
Just make sure you clean everything up real well, keep track of all the nuts, bolts and connectors and take your time. You will learn a lot from this job.
stumpjumper is offline   Reply With Quote
Old 06-25-2006, 03:23 AM   #4
h8z2luze
h8z2luze's Avatar
h8z2luze is on a distinguished road
I am in the middle of one right now Havent even got to drive my supra yet lol.
1989 Supra 7MGE MK3 5-speed project...
http://www.cardomain.com/ride/2385505
h8z2luze is offline   Reply With Quote
