-   -   Code 25 and 26 (http://www.toyota-supra.info/forums/mkiii-supra/5123-code-25-and-26-a.html)
f00g00 06-21-2006 04:44 PM
Code 25 and 26
1 Attachment(s)
Well to start I had this JDM engine installed here in the local scrapyard by the afghani's about 6 months ago (they said they don't like the taleban btw). I've allways had a slightly rough idle and lately the idle did the old up and down routine to 1800 down to norm constantly. I changed all the intake manifold gaskets except the ISC valve which I had to make myself as they company here didn't have one.
Well to make a long story short, none of the above fixed the problem. 25 and 26 started about a week ago and came on twice.
The attatched photo shows the culprits. They are my old injector packings that were installed by the taleban militia and as you can see the 3 on the bottom were pinched during installation. I showed them in the pic upside down to better show their distortion.
I put in the new packings and now it runs smooth and has a bit more power.
theWeezL 06-21-2006 06:13 PM
yep! that would be a problem.
suprra_girl 06-25-2006 06:31 AM
thanks for posting up your results for future readers :)
joel w 06-25-2006 06:42 PM
Great thread... :)
Good title, some politics, a lot of self help, and a cure all in one post with pics..
<two thumbs up with a glof clap>
jfunez 06-25-2006 08:38 PM
hey joel... you missed mentioning the good looking girl.....
my respect to supragirl.....:bow:
joel w 06-25-2006 10:29 PM
In algebra terms, Suzi is a given (goes without saying)...:drool:
And I was referring to the first post alone... ;)
jfunez 06-26-2006 03:32 AM
Originally Posted by joel williams
Great thread... :)
you refered to a GREAT THREAD.... I assumed by that you were speaking of the whole trhead not just the first post...
anyways.............
Murd 10-04-2006 10:05 PM
*revives dead thread* My car started stuttering on acceleration and running rough on idle. So I did a diag, and pulled up codes 25-26. Running to rich, and too lean. Anyway I searched the board and found this post. Before I tear into this and replace the seals on the injectors, is there anything else I should do or check while I have em out?
f00g00 10-05-2006 07:13 PM
What I did with my injectors while they were out was to power them open and use a can of carb cleaner while they were open to clean them out. You just have to take a spare plug with a couple of feet of wire and hook them up to a battery to energize the injector open. For the carb cleaner use the kind that has the straw and wrap a little tape on it so it seals at the injector opening and spray till it comes out in a good pattern, usually only takes a few seconds. And by al means use goggles when you do this so you don't get any in your eyes!
Also a faulty ox sensor might cause this too.
Supra2NR 10-06-2006 07:58 AM
i dunt mean to jack the thread(which i seem to do a lot)
but im jus curious. code 25-26
do u mean to say running to rich OR to lean
not and
cuz i wanna know how do u get to run rich and lean at the same time
Murd 10-06-2006 12:23 PM
not and
Just reading what the TSRM says.
http://www.cygnusx1.net/Supra/Librar...ion=FI&Page=27
Isphius 10-06-2006 02:00 PM
If your injectors are messed up and spraying too much or too little fuel each time. Or if your o2 sensor is bad, like stated /\
Murd 10-17-2006 08:45 AM
OK it's been a week, and AutoZone hasn't shipped my parts, mainly the Injector O-rings... GRRRR!!! Anyway, my wifes car crapped out on her, so just to have something running I put mine back together, I found a vaccuum line disconnected when I was pulling it apart anyway so had some suspicions. Got it all back together and the only thing I really replaced was the plugs, and the rotor <cap, wires and o-rings not shipped>. Ran a diag, no codes all clear. Drove it around for about 20 minutes, rechecked codes, no codes all clear.So it looks like it was a vacuum line causing the issue. I'll keep an eye on it and keep you posted on how it's running. Anyway just wanted to post a followup post about it.
