Old 06-20-2006, 07:42 PM   #1
h8z2luze
h8z2luze's Avatar
Question How to clean injectors?
Whats the most effective way to clean injectors?
Old 06-22-2006, 04:32 AM   #2
supfoo514
supfoo514 is on a distinguished road
I'm not sure if there is a better way of cleaning your injectors but you can buy a couple of bottles of injector cleaner from your local kragens, autozone, etc. and put it into your tank the next time you fill up. It should clean your injectors as you drive.
91 Turbo Automatic MKIII
a.k.a "Sammie"
supfoo514 is offline   Reply With Quote
Old 06-22-2006, 04:34 AM   #3
h8z2luze
h8z2luze's Avatar
I mean as they are removed from the motor. Just blow air trough them or what?
Old 06-22-2006, 05:49 AM   #4
f00g00
Well scince you went to all that trouble.
I did it with them removed by getting some carb cleaner and put a little tape aroung the straw that came with the carb cleaner so when installed in the fuel inlet it had a good fit. The you need to open the injector so I had an injector plug from an old harness, hooked the wires to 12 volts and sprayed till the pattern was good once the injector was open.
A little advice though is wear some goggles or something to protect your eyes from getting flying debri or cleaner in them.
Now I use the method mrnickleye talked about here.
http://www.toyota-supra.info/forums/...ead.php?t=4658
Old 06-22-2006, 10:32 AM   #5
Cool
there are places that will professionally clean and balance fuel injectors . i think for around $25 per injector
Old 10-14-2006, 04:38 AM   #6
captwilddog
captwilddog is on a distinguished road
im not sure but i believe 12 volts is to much voltage on the injectors
captwilddog is offline   Reply With Quote
Old 03-11-2008, 11:19 AM   #7
carfanatic89
carfanatic89's Avatar
yeah I would think that 12v would damage something
Supra Engine Powered Dragster
Old 03-11-2008, 05:35 PM   #8
Correct voltage is around 1.5V to 3V... Using a single AA Battery works great.
Old 03-11-2008, 08:34 PM   #9
carfanatic89
Will It hurt the injector if you connect it backwards, I wouldn't think so, I think It just wouldn't open the injector.
Old 03-11-2008, 11:25 PM   #10
I'm not sure if it hurts it... When I did that to test my injectors, they just didn't open when the polarity was reversed. I haven't had any problems with them since I've checked them out, so I don't think it hurts them, but I wouldn't do it if at all possible (just in case it does).
A Few Q's on Turbo Injectors Chambers MKIII Supra 9 11-06-2007 03:26 AM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
Cleaning Intake & Injectors mrnickleye Supra FAQ 6 03-23-2007 04:26 AM
