Old 06-19-2006, 08:58 PM   #11
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
absolutley. thats what its made for
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 06-19-2006, 09:18 PM   #12
Ahmad88
Ahmad88 is on a distinguished road
ok thanks for the help man preciate it
Ahmad88 is offline   Reply With Quote
Old 06-20-2006, 12:02 AM   #13
jfunez
jfunez's Avatar
also one thing we are not telling him is that there is a posibility that the coolant is also being lost during driving. as in my case ,I would only loose coolant during highway speeds due to a small leak on the headgasket, exaust gasses would leak into the coolant chamber and push out the coolant through the reservoir since radiator pressure slowly creeped up and went past the pre-determined rad-cap pressure. about two weeks later came some power loss and a more frequent refilling of the radiator....
Old 06-20-2006, 10:34 AM   #14
ddmcse
ddmcse's Avatar
Cool
this is known as the BHG
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 06-20-2006, 11:18 PM   #15
jfunez
jfunez's Avatar
thats correct DD..
Old 06-21-2006, 04:57 AM   #16
"sharp"
"sharp" is on a distinguished road
Thumbs up
ok thanks everybody. I found a blown hose. wasnt very fun but i got it fixed. the problem now is that I filled everything up but the light wont go off. do i need to reset something or what?
"sharp" is offline   Reply With Quote
Old 06-21-2006, 10:00 AM   #17
ddmcse
ddmcse's Avatar
Cool
you didn't fill up the bottle up front, thats what makes the light go on
it's outside the engine bay near the front left headlight
btw , what do you think made the hose blow ?
now is when you want to make sure you do not have any air pockets/air bubbles and it's completely topped off .
you need to watch it closely
the reserve bottle and the radiator watch for ANY water usage
and listen for a rushing water sound in the dash when you start up in the morning
My Supra KiXGaS
Old 06-21-2006, 01:00 PM   #18
Ahmad88
my check engine light wont go off and my brake light wont go off.. whats with that? the check brake lights light is on above the check engine light, sometimes it goes off, do i need to fill that container next to the left headlight to turn off the check engine light?
Rollin in a 98, flippin 94's
Old 06-21-2006, 02:23 PM   #19
ddmcse
ddmcse's Avatar
Cool
you need to do a diagnostic of the error codes your engine is throwing .
you jump connections on the diag box in the engine bay
and the engine light blinks a morse code type blink
My Supra KiXGaS
Old 06-21-2006, 03:17 PM   #20
IHateHacks
IHateHacks's Avatar
He didnt know coolant could go into the coolant recovery reservoir, I doubt he is going to be able to check his codes.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
