Old 06-08-2006, 12:05 AM   #1
rnoswal
rnoswal's Avatar
Angry 87 R Rear hub removal????HELP!!!!!!
I am trying to swap out the right rear hub from a donor to my current car. I took all the bolts out, the axle nut and for some reason expected the hub to slide right off the axle........WRONG!!!!!!! I have taken front wheel drive hubs off very similar to this set up and after taking the axle nut off it just slides out. Am I missing something or do these rust weld themselves on and have to be tossed? I have a small puller and put it on the hub and tried screwing it against the axle but nothing. Tapped it with a hammer, nothing. I even beat it with the hammer and ended up making it hard to screw the axle nut back on.
The book sheds lo light nor the cd manual. I am hoping there is a pinch bolt or a pin that I am missing somewhere, but I can't see any. So any help would be appreciated.
Thanks
Russ
Old 06-08-2006, 03:21 AM   #2
jfunez
jfunez's Avatar
ummmm .. what?
Old 06-08-2006, 04:22 AM   #3
TONY!
TONY!'s Avatar
TONY! is on a distinguished road
I am not sure if this will help you but it may:
I removed both of my rear axles.
One came off pretty easy and one just would not slide off!
I had to hammer the hell out of it. Maybe some penetrating oil will help you...
If this pic helps at all, feel free to take a gander:
http://img.photobucket.com/albums/v5...R/PICT0870.jpg
-------------> ITEMS THAT ARE STILL AVAILABLE FROM AN '88 PART OUT <-------------
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
____________________[||]______________[||]____________________
TONY! is offline   Reply With Quote
Old 06-08-2006, 12:30 PM   #4
rnoswal
rnoswal's Avatar
Well thanks TONY. That confirms what I thought, but was hoping I was missing something. I guess it is time to get out the big hammer, sure hate losing an axle that way though.
Russ
Old 06-08-2006, 01:59 PM   #5
theWeezL
theWeezL's Avatar
try some Blaster in there, let it sit for a few hours, and come back and give it one hard knock, I bet it pops right off!
____________
Rusty Rear Wheel Arches Bill UK Non-Generation Specific Questions 1 01-21-2007 10:07 PM
Rear ended Gmrwizard MKIII Supra 1 02-24-2006 01:33 PM
Supra rear ends Gmrwizard Non-Generation Specific Questions 0 02-22-2006 02:03 PM
