Old 06-03-2006, 04:40 AM   #1
skateboarder0102
skateboarder0102 is on a distinguished road
Default 7m-gte swap problems
i swaped a jdm 7m-gte with 550 injectors and a lexus afm. at first the car didnt run right so i put the cam angle sensor/distributor coreclty and it ran better. The person that had the car before me put new clips in for the fuel injectors and i figured that the clips will go in order to the fuel injectors. The last two clips are like right next to each other so i tried it both ways and i think i got it in right. now the car just wants to die right away with out me being on the gas when i turn it on. so i ajusted the throttle body so the car will stay alive. now when i drive it the blow of valve does not want to go of at all. i have a turbo smart bov with some custom piping. when i shift gears and give it gas it wants to stutter for a bit and then if finnaly goes. why does my blow of valve not want to go of i looked at it with a friend and it looks fine. would i have a vacumm leak some were in my piping. i actually looked for leaks and cant find anything.
skateboarder0102 is offline   Reply With Quote
Old 06-04-2006, 01:11 AM   #2
White87Turbo
White87Turbo is on a distinguished road
Im having the same problem with mine and cant figure out what it is. Im running a stock bov so im guessing its something other than that.
White87Turbo is offline   Reply With Quote
Old 06-08-2006, 03:09 AM   #3
jfunez
jfunez's Avatar
i dont know, but it sounds like a leak somewhere....
mkII common problems..and swap?? the_trooper08 MKII Supra 0 09-04-2007 02:11 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
89 Supra Turbo w/1JZ Swap Problems Donnies Foreign Car Non-Generation Specific Questions 1 02-02-2006 05:03 PM
PROBLEMS WITH MY TURBO SWAP Supra GuestOBRUT89 Non-Generation Specific Questions 3 03-14-2005 06:51 AM
