Old 05-31-2006, 12:51 AM   #1
jaysun
jaysun's Avatar
jaysun is on a distinguished road
Default Low Beams Dont work!?!?!
i have a n/a supra, my right side light doesnt turn on when its on low beams, but when i switch it to high beams it works. i know its no the fuse because the left side works on low beams and high, the fog lights work just fine. i dont know what happened. any clue?
-Jason
7m-ge
auto tranny
non turbo
so far stocked ..
jaysun is offline   Reply With Quote
Old 05-31-2006, 01:29 AM   #2
tonystarks
tonystarks is on a distinguished road
Cool yeah
i think your headlight is burned out..... 10o pesos at vato-zone
86.5 MK Trey
7MGE
K&N Filter Kit
cheap ass exhaust
turbo swap in a few months
tonystarks is offline   Reply With Quote
Old 05-31-2006, 09:45 AM   #3
kewlcoconut
change the bulb. headlights have high and low beam. the low beam is toast on that light.
Old 05-31-2006, 04:06 PM   #4
Kai
Kai's Avatar
Kai is on a distinguished road
Cool
Hehe - i had that a few weeks back. Bought a new pair of the Xenon Blue ones for about ?8 each. Fitting them was a pain in the ass seeing as the 4 screws holding the glass in place had been slowly rusting away for god knows how long....
Kai is offline   Reply With Quote
Old 06-01-2006, 06:19 PM   #5
supfoo514
supfoo514 is on a distinguished road
I have a similar problem except both of my low beams dont work. I was wondering are there suppose to be two bulbs inside the lamp or just one? And also does this mean I have to replace the whole lamp in order to get the lows to work or can I just replace the bulb? Thanks.
91 Turbo Automatic MKIII
a.k.a "Sammie"
supfoo514 is offline   Reply With Quote
Old 06-01-2006, 10:40 PM   #6
burton51m
burton51m's Avatar
Post
the low beam lightbulb is burnt out. the bright lightbulbs are fine. take your lights apart and figure out which ones need replaced in each light. you do not need to replace the whole light and spend money on stuff that already works correctly. just replace the bulbs.
what do you do anyway...drive around with your brights on all the time?lol
Old 06-02-2006, 09:59 AM   #7
Kai
Kai's Avatar
The H4 bulb used in the headlamps contains two filaments - one for the low beam, one for the main beams. Thats why there are three wires going to it - one common ground, and two positives
Old 06-02-2006, 06:52 PM   #8
MK3_300
MK3_300 is on a distinguished road
I'm sorry, I may have missed it but did you say you've done a (replaceable bulb) H4 conversion? If so then yes you can replace just the bulb, but if not you may still have the OEM style sealed headlights. In that case you will have to replace the entire lens/housing assembly. You can get them anywhere that sells auto headlights. Either style you have, I would recommend replacing them with Silvanya(sp?) Silverstar headlights....much better lighting for only a little more cost.
Also my drivers side high beam dosen't work but my problem was that the high beam positive wire had broke off from the connector. You might want to check your harness wires when you take the headlights out.
MK3_300 is offline   Reply With Quote
Old 06-04-2006, 01:41 AM   #9
supfoo514
Yea...I pretty much have to drive around with my high beams on all the time because I don't want to get pulled over....but I do want to fix my low beams. So if I still have the stock housing then I will need to change the whole thing? As opposed to just changing the bulb if I had an aftermarket housing? Thanks.
a.k.a "Sammie"
Old 06-04-2006, 02:06 AM   #10
damdog05
damdog05's Avatar
correct. if you havent converted then you have to replace the whole thing. its easy though, just four screws and they come out. and seriously, go for the silverstars, they are sooo much better and theyre not that expensive.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Dash lights Don't Work supra67 Non-Generation Specific Questions 4 09-05-2006 04:58 AM
Dash lights Don't Work!! supra67 MKIII Supra 0 08-10-2006 01:11 AM
Will these work in a 7mge Isphius MKIII Supra 2 04-26-2006 04:54 AM
