Old 05-28-2006, 08:48 PM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default Head bolts
Do you have to change them every time you take them out ?
well not every time but like when you change the head gasket ?
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 05-29-2006, 02:38 AM   #2
TONY!
TONY!'s Avatar
Aren't head bolts torque to yield?
I thought that they were.
APR studs are about $110, but you can get stock bolts from the dealer much, much cheaper, and probably still cheaper if you buy them from www.toyotaworld.com ...unless the shipping exceeds the savings.
I think that my local dealer charges like $3 a bolt.
Here is a link to torque to yield info as well as other head bolt info as well, that may be of interest:
http://www.federal-mogul.com/cda/con...9_7465,00.html
I know that my head bolts were obviously unusable because the threads had noticable wear.
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
Old 05-31-2006, 10:47 AM   #3
G-string
G-string's Avatar
Can any one els tell me for sure if i need it for sure ?
For soem reason i already put on the cams and tryed to get the timming right so im kinda hoping the ones that were on it before would be ok but i dont want to do this again so do i really need to buy new head bolts and put them in ?
Old 06-01-2006, 01:30 PM   #4
rnoswal
rnoswal's Avatar
No, you can reuse the head bolts. They aren't the best for performance, but I have reused them several times with no problems. Just make sure you torque them down to 72 ft lbs. You could buy the ARP studs and replace them one at a time, torqueing them back to 72 lbs then, with all the studs replaced go to 85 lbs to finish the job. But you can reuse the stock ones since you already have.
Russ
Old 06-01-2006, 05:36 PM   #5
G-string
G-string's Avatar
thanks alot every one i called the toyota place to ask hwo muhc they were gona rip me off to get a set of new ones and they said they wernt torqued to yield
Old 06-02-2006, 01:04 PM   #6
rnoswal
rnoswal's Avatar
What was their torque to yield figures? Just curious as compared to what the rest of us now know just what they should be torqued to.
Russ
head bolts on jdm engine tone loc MKIII Supra 10 06-03-2007 09:33 PM
head gasket bolts marc MKIII Supra 6 10-23-2006 07:23 PM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
ARP head bolts Deputy99 MKIII Supra 2 07-19-2006 11:16 PM
