Old 05-27-2006, 09:47 PM   #1
Levi1717
Levi1717's Avatar
Levi1717 is on a distinguished road
Default GTE into GE
ok i have a 87 n/a and i would like to put a 87 7mgte with wireing harness and ecu in what problems might i run into like with ignition stuff and otehr wiring. i just want it to go smothly and have a wealth of knowledge before the transformation.
87 N/A with a new JDM 7mge.
Looking for a 7mgte
Levi1717 is offline   Reply With Quote
Old 05-28-2006, 01:47 AM   #2
Kai
Kai's Avatar
Kai is on a distinguished road
Well, aside from looking around the boards for other similar topics, you could also check here: http://4cefed.com/conversion.html
Kai is offline   Reply With Quote
Old 05-28-2006, 09:00 PM   #3
G-string
G-string's Avatar
G-string is on a distinguished road
wow im confused so you want to make it a turbo to a non turbo ?
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 05-29-2006, 01:36 AM   #4
Kai
Kai's Avatar
No - he wants to put a 7M-GTE into a 7M-GE shell
Old 05-29-2006, 03:04 AM   #5
Levi1717
Levi1717's Avatar
yes thank you i want to buy a 7mgte and take out my practically new 7mge then sell both my 7mge's (one with serious rod knock) to buy new parts for my gte
Looking for a 7mgte
Old 05-29-2006, 06:11 AM   #6
i'm not sure about usdm but from what i can tell in jdm (pretty similar i should imagine) you need to just rewire one plug at the fusebox as they use a different type of plug but wire colours are the same
and do the resistor change in the tacho
i'm sure someone here has a link to that somewhere
Old 05-29-2006, 09:30 AM   #7
Kai
Kai's Avatar
I know about the tacho - thats covered under the conversion notes page i pasted above - but i thought you had to use the whole 7M-GTE loom because it uses a coil pack and different ignition?
Old 05-29-2006, 10:17 AM   #8
of course hence you need to change the body harness plug as 7mgte harness don't fit 7mge body harness
Old 05-29-2006, 10:50 AM   #9
Kai
Kai's Avatar
Damn - now *i'm* confused!!
Old 05-29-2006, 01:49 PM   #10
Levi1717
Levi1717's Avatar
wait so what do i need to cahnge on the wiring harness to the body?
Looking for a 7mgte
