Old 05-19-2006, 06:06 PM   #1
KNYFE
KNYFE's Avatar
KNYFE is on a distinguished road
Default Uh oh... Help?
Well, I had my Supra at my car guys shop and he was going to put my new wheels on. We went for a short drive before so he could hear a new noise that I was getting.
The engine has began knocking under any acceleration, the oil pressure is at about 20 or lower and I fear for my engine.
Only things that have been done are oil change and coolant added.
Anyone have any idea what it may be? I have an unemployed "gear head" friend who has offered to do a teardown if necessary but I'm hoping for a simpler fix.
http://www.cardomain.com/id/FastnLowI30
Supra, I30 and A8 are above...
KNYFE is offline   Reply With Quote
Old 05-19-2006, 08:18 PM   #2
KNYFE
KNYFE's Avatar
Current thought is a thrown rod.... *sigh*
Well, this may be the chance to rebuild her... "Stronger... Faster..." or whatever. Guess I'll have time to do the interior work now.
Old 05-19-2006, 10:11 PM   #3
rnoswal
rnoswal's Avatar
As a general rule the oil pressure should be 10 for every 1000 rpms, so 20 for 2000 and so on. If it is 20 or lower while driving, a lot of us would say change out the sender for a new one, but if it is rattling then it is time for a rebuild. No cheap way about it, except for labor if you can do most of it. The engine has to come out and almost everything will have to be replaced.
The crank can be ground if it hasn't rattled too much, the rods can be re-used, but you should put ARP bolts in them. The cylinders will probably be worn out and need reboring and new pistons. You may as well get the head done too while it is off. Valve job and probably a few valves or more and maybe even guides.
It will be like a new engine when you finish and it will be worth it. With good maintenance you can get several hundred miles out of it again. Put in a metal head gasket and studs to make sure that doesn't go first. I wish FelPro made good gaskets for these engines like they do for almost every other engine. Not the gray graphite gaskets, but their blue colored performance head gaskets. I have used them for racing a modified and my Toyota Celica with never one problem, but I just don't think they make them.
Good luck and keep us up to date.
Russ
Old 05-19-2006, 10:20 PM   #4
stock oil pressure for a 7m is 4.6psi at idle
usually 20 or something when cruising?
and you're sure she's a knockin in the bottom end?
Old 05-20-2006, 02:06 AM   #5
TONY!
TONY!'s Avatar
Does it sound like this?
http://www.geocities.com/ma71supratu...h/rodknock.mp3
Keep in mind that a spun bearing can sound differently in different cases, not to mention that sounds in life may sound different than what you would have from recordings and replays.
If you have a spun bearing, you may see shavings in the oil.
That would be one way of diagnosing it; check your oil after you dump it.
Another way of diagnosing it is to remove one spark plug wire at a time to see if the sound goes away or changes greatly. Removing a spark plug will decrease the cylinder pressure and therefore decrease the pressure on the piston, which in turn is tranfered to the rod.
Another way of diagnosing it is to spend a whole ten dollars and buy yourself a mechanic's stethoscope as sold on eBay, then learn how to interpret what you hear.
First do the diagnosing, and then I'll tell you more if need be.
Old 05-28-2006, 02:49 AM   #6
supradaddy0803
supradaddy0803's Avatar
Default here is what I have found
I had the same problem with my 86.5 and I tore the whole motor down and rebuilt it all cost me like 1500 bucks for all the parts to my supprise that there was no problem with the crank it was still within limits by my handy shop manuel. So I did some checking and found a guy talking about the same thing and he said 7MGE motors are very intollerant of low oil even by the least bit. So this explains the oil pressure being right and the knock check the oil and make sure it is full. Mine does this also but has a leaking rear main seal so when it gets low it is a good tell all it is low. Also check for oil leaks you cant see like from the distributor oil seal with all the air intake stuff in the way it is hard to see if it is leaking thats where the leak on my 86.5 was baffled me never smelled the oil cooking funny I have had a 86.5 a 87 and a 84 only time I have seen that.
