Old 05-17-2006, 07:49 PM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default Blow off valve
What exactly does it do?
And where is it?
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 05-18-2006, 07:59 PM   #2
burton51m
burton51m's Avatar
wikipedia...
http://en.wikipedia.org/wiki/Blow_off_valve
Old 05-21-2006, 07:27 PM   #3
G-string
G-string's Avatar
What are the diffrent kinds of blow off valves ?
I heared there is piston and some other kind, what is the diffrence between them ?
Old 05-23-2006, 12:27 AM   #4
G-string
G-string's Avatar
Ok i think i get how it works and where it goes so good good but then i read soemthing about the ECU expecting more air and not getting it and pumping to much fuel in ?
so would my supra have that problem and if so what would i do about it ?
Old 05-23-2006, 01:14 AM   #5
joel w
joel w's Avatar
I have heard of people having issues with venting it to the atmosphere, if that is the case you can get an hks ssqv and the adapter to route the air back into the accordian hose like stock (steath mode). I personally don't have any problems venting it to the atmosphere on mine. Maybe and occasional "pop" from the muffler..
Old 05-24-2006, 08:17 AM   #6
G-string
G-string's Avatar
wicked, good to know so there isnt realy anything bad about having a blow off valve
Old 05-24-2006, 03:37 PM   #7
Cool
i'm in the same boat as joel
i dump to the atmosphere , i supposed if i was going to blow the coin again on a BOV i would go with one that doesn't dump and re-circulates
Old 05-24-2006, 08:22 PM   #8
G-string
G-string's Avatar
why would you chose to re-circulate instead of dump ?
Blow off valve / idle issue AlpWhitE46 MKIII Supra 9 10-10-2008 11:49 PM
need help with blow off valve birdman9119 Non-Generation Specific Questions 0 07-05-2008 05:44 AM
blow off valve adapter projekt6 Non-Generation Specific Questions 1 04-04-2006 11:25 AM
