Old 05-16-2006, 05:04 AM   #1
1988gte
1988gte is on a distinguished road
Default boost
Has anybody had the problem of boost jumping? What i mean is when i hit around 3000 rpms the car just feels like the turbo pressure jumps, from little or none to around 8lbs or more. I read somewhere about our guages not being that accurate or fast to give us good reading, but it jumps to
1988gte is offline   Reply With Quote
Old 05-16-2006, 05:08 AM   #2
Burn N' Up
Burn N' Up's Avatar
The boost jumping is the tubro spooling up...
Old 05-16-2006, 05:12 AM   #3
1988gte
i know that much , but never used to have lag then jump. It was always smooth around 1800+ rpms then the hard pulling to red line
Old 05-21-2006, 03:41 PM   #4
1988gte
was air filter
Old 05-21-2006, 04:02 PM   #5
joel w
joel w's Avatar
"Was air filter?" Does that mean it was the air filter causing your problems?
If not, Check your vacuum line that runs to the waistgate actuator on the turbo for leaks/cracks. Check all your vacuum lines while your there.. Get an aftermarket gauge installed as the stocker is a POS.
Old 05-22-2006, 04:53 PM   #6
1988gte
yeah i was saying it was the airfilter.(sorry i was running late for a meeting at work) I took it off to test it, and thought it was fixed but did it again. I read what you said about the wastegate line, sure enough cracked, hard, torn, everything. thanks for the info my babys back to normal
Old 05-22-2006, 05:22 PM   #7
joel w
joel w's Avatar
Your welcome..
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
