Old 05-09-2006, 10:49 PM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Temp. Sender-what does it do?
After completing my recent BHG on my 1990 Turbo, the computer set a code for bad temp. sender--found it to be the one behind the PS reservoir bracket-the 2 prong thermistor. Checker and AZ don't have them, so it was $59 for a new one at the Toy. dealer.
BUT, I also found another temp. sender w/1 blade connector that is in the radiator side of the t'stat housing. There are 2 on this side, the lower one runs the elect. AC fans, and this one up higher. It tested open (infinite ohms to ground). The dealer had one, so I tested it right at the parts counter--same thing, infinite ohms. No sale. Then I tested the orig. one hot-no change.
What is the purpose of this sensor/sender? It doesn't run the temp. gage. It also doesn't set any codes.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 05-10-2006, 12:34 AM   #2
ddmcse
ddmcse's Avatar
Thumbs up
you need a TSRM
you can dig one up from ebay. you need a real toyota manual too not a knock off
page FI-94 to FI-95
in my manual
i don't find it fast on the online one .
http://www.cygnusx1.net/supra/librar...fi/FI_084.html
one is a cold start switch for the cold start injector
one is temp
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-10-2006, 03:06 AM   #3
Benesesso
Benesesso's Avatar
I have 2 genuine Toyota service manuals. Thw sender in question is not the cold start goodie--that one is on top and on the engine side of the t-stat.
The unknown sender is ~halfway down the side on the radiator side. I couldn't find it in the manual.
Water temp gauge dead Fredde MKIII Supra 4 05-27-2008 12:40 AM
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Petrol Gauge Sender Supra Mk3 supra mk3 brunei MKIII Supra 0 02-17-2008 04:14 PM
strange temp gauge activity D_Train MKIII Supra 21 08-25-2007 05:43 PM
Coolant temp sensor thread size?? petey turbo MKIII Supra 5 02-12-2007 06:15 PM
