Old 05-05-2006, 08:34 AM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default Crank pully removal
I just finished replaceing the head gasket, still nto sure how well it will do but i guess il see
In the process i saw my timming belt was warned and cracked so i got a replacement but it seams to eb harder to do all that stuff then i thought, Any sugestions oh hwo to remove it ?
I have the cams off so dont have to worrie about bending the valves (If i havent already)
I just need to remove the remove the crank pully so i can get the bottom cover offto remover the beltand what not
Any sugestions would be much apreciated (I know i probly spelt that wrong)
G-string is offline   Reply With Quote
Old 05-05-2006, 09:32 AM   #2
ddmcse
ddmcse's Avatar
use a breaker bar to loosen the pulley bolt . if you do get it off make sure to to use a torque wrench to put it back on tight. the manual says to torque it down to 196lbs . if it gets loose on you it will damage the inside of the pulley and the crank shaft.
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-05-2006, 10:23 AM   #3
G-string
G-string's Avatar
i cant use a breaker bar it just turnes the whole crank shaft so the pistions move
Old 05-05-2006, 11:17 AM   #4
f00g00
If you have a manual trannie put it in gear and have someone step on the brakes, if an auto you will probably need air impact tools like the ones used to put on tires.
Old 05-05-2006, 02:00 PM   #5
ddmcse
ddmcse's Avatar
oh i did forget to mention it's a 2 man job and you need the brakes stepped on and chocks and in gear and all that good stuff
My Supra KiXGaS
Old 05-05-2006, 02:06 PM   #6
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
First, you won't bend any valves. Supras are "non-interference" engines, fortunately. If you can't prevent the crank from turning by some simpler method, you can have a 3" rod welded to the end of an old spark plug. Use a rod about 7/16" dia.--just small enough to slip thru the threaded hole. Grind the sharp edges off the bottom and screw it all the way into a spark plug hole. It will stop that piston from rising more than ~halfway, and the load on the piston won't be very high, compared to what it would be if you use a short rod.
AFTER I got my damper off I used a big drill bit to countersink the threaded holes on the front. As I recall I had a hard time getting the puller bolts into the stock threaded holes.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 05-05-2006, 10:53 PM   #7
dcrusupra
dcrusupra's Avatar
Put a breaker bar on it, make it so that the handle touches the floor. Then just blip the ignition quickly. Bad things will happen if the car starts. Lol.
New Rebuild
My CarDomain
Old 05-07-2006, 11:09 AM   #8
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
^ LOL
yep... blip the ign if you can't get it loosened with a breaker bar
then use pulley claws to take the crank pulley off
Pics of my build.
Do a diagnostic first!
Crank Shaft Pully Question kidsusukigsxr Non-Generation Specific Questions 1 04-15-2011 08:45 PM
Crank Pulley Removal go.stfu MKIII Supra 4 07-12-2007 11:16 PM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
Need help with front crank shaft pully bolt tmetal_blk Non-Generation Specific Questions 3 06-24-2007 06:24 PM
Crank Pully timming G-string MKIII Supra 2 05-25-2006 12:11 AM
