Old 04-28-2006, 03:15 AM   #1
ddmcse
ddmcse's Avatar
i vote isc
you can probably get a second hand one cheaper that what you have to pay this person looking at your car
you need to find out the codes it really helps alot
http://www.cygnusx1.net/supra/librar...fi/FI_028.html
http://www.cygnusx1.net/supra/librar...fi/FI_106.html
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 05-18-2006, 02:34 AM   #2
tonystarks
tonystarks is on a distinguished road
Default fawkin isc
yeah it was the idle speed control valve!! I had one lying around the entire time and ended up spending around 346 and some change for nothing.... well not entirely but I changed the fuel pump, filter and ecu. oh well at least I know that shiet is newer
86.5 MK Trey
7MGE
K&N Filter Kit
cheap ass exhaust
turbo swap in a few months
tonystarks is offline   Reply With Quote
Old 05-18-2006, 02:45 AM   #3
rnoswal
rnoswal's Avatar
Another problem I ran into was that with an aftermarket filter kit, the cooling fan can blow into the intake area around and into the filter causing an erratic idle. I moved it further forward and out of the fans airflow and it cured my problem. The ISC can be a problem too, but the filter should have a shield around it if it is just stuck on the end or the AFM like mine is.
Good luck and let us know how it goes.
Russ
My fenders look wrong Kristian_Wraae Non-Generation Specific Questions 14 05-07-2007 03:20 PM
need help quick think something is really wrong brs86supra MKIII Supra 6 02-13-2007 07:43 PM
intake manifold has coolant what did i do wrong? 91toy supra MKIII Supra 6 09-16-2006 02:46 PM
Stock Block Evilfurby MKIV Supra 56 01-09-2006 02:23 AM
