Old 04-27-2006, 10:50 PM   #1
Supra1989
Supra1989's Avatar
Supra1989 is on a distinguished road
Default broken fans
hello fellow supra lovers
my problem - the lower small fan on my radiator decided to come off due to crappy crafstmanship and the the large engine fan got jammed in the plastic guard and broke one of the tips off
so i took out the cracked up guard(im not sure waht its really called) and disconnected/removed the thing with the 2 small fans
im wondering if it would be fine to drive with just the one small fan and the big one
obviously you can tell i dont know much about cars..
but i love my supra as if it were my child
any help/tips is greatly appreciated!
Supra1989 is offline   Reply With Quote
Old 04-28-2006, 03:02 AM   #2
Burn N' Up
Burn N' Up's Avatar
Mr. Toyota designed it with three fans for a reason....
Old 04-28-2006, 03:50 AM   #3
i would replace the belt driven fan with an electric one and gain the 8-10 hp . you can tap into the electric wires left over by the small fan
the small ones are for an extra boost when the ac is running
i have pictures on my website under modifications
http://www.ddmcse.com/turbo/modify.htm
fan setup costs around 100$ an easy 10 hp is priceless right ?
the plastic shroud costs around 150 i think
you need some kind of fans for sure
Old 04-28-2006, 09:28 PM   #4
Burn N' Up
Burn N' Up's Avatar
I agree with the fan swap whole heartdly, in fact its happening after my next check, hooray for tuning on a budget
Old 04-28-2006, 09:35 PM   #5
Supra1989
Supra1989's Avatar
thats what i was thinking
these look nice http://www.suprastore.com/elfankittwin.html but they are a bit too pricy..
i wonder where in town i could find something similar..?
Old 04-30-2006, 06:50 AM   #6
I've been running with electric for 3 years here in the desert. Check this out. http://www.jegs.com/webapp/wcs/store...0117&langId=-1
14" fan fits easy. 1800CFM is plenty of air movement. Get an automatic temp relay kit, and ad a manual over-ride switch at one of the 'coin' holder slots.
Broken Thermo Bolt scruffboy MKIII Supra 17 10-08-2010 01:03 AM
hydraulic fans oowee623 MKIII Supra 2 09-03-2007 05:22 AM
Electric fans fulljapan Non-Generation Specific Questions 4 08-14-2007 03:28 PM
Broken Bolt scruffboy Non-Generation Specific Questions 6 10-31-2006 01:33 PM
