Old 04-19-2006, 09:53 AM   #1
G-string
G-string's Avatar
G-string is on a distinguished road
Default Head Gasket work
I have finaly got everything off, Now just so i dont screw my self over completly
I take off the old gasket
scrape off the what left over
I cleaned all the cooling vents on the block (that was some nasty stuff)
How do i check if the head has warped ( I hope to hell it hasent)
I have a replacement head gasket set
what els should i do before i start putting it back togeather?
G-string is offline   Reply With Quote
Old 04-19-2006, 12:54 PM   #2
ddmcse
ddmcse's Avatar
Cool
start calling head shops to have it looked at
i don't mean where you buy bongs either
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-19-2006, 05:35 PM   #3
sevenmgte
sevenmgte is on a distinguished road
Default need help
how did u take off cam gears on ur engine im doing same thing just got done pulling every thing off to?? how u clean ur cooling vents????
sevenmgte is offline   Reply With Quote
Old 04-19-2006, 09:10 PM   #4
kewlcoconut
kewlcoconut is on a distinguished road
you better hope that your head isnt warped. mine was, it was warped really bad. my mechanic had to send it out to a specialist so they could alumminum splatter it and fix it. would have cost me a lot but he did it for me at his cost. which was still about $300.
kewlcoconut is offline   Reply With Quote
Old 04-20-2006, 10:17 AM   #5
G-string
G-string's Avatar
I took off the cam gears by using a monkey wrench to hold the cam shafts where the notch is and then it doesnt move,
Im having trouble taking off the crank pully, im putting on another timming belt, any ideas
Im confused am i checking to see if the cam half of the head is warped or the piston half or if both are warped
Old 04-20-2006, 11:23 AM   #6
ddmcse
ddmcse's Avatar
http://www.geocities.com/MotorCity/S.../1636/bhg.html
My Supra KiXGaS
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
N20 and HeAd WoRk Supra_87_mk3 Non-Generation Specific Questions 4 05-25-2007 03:09 PM
