Old 04-19-2006, 08:37 AM   #1
SCRAMJET
SCRAMJET's Avatar
Default intercooler+hoses
I've heard that the standard supra intercoolers aren't that great. I'm thinkin about changing my intercooler and intercooler pipes but i wanna know, if i'm gonna fork out the coin, that it's gonna be worth my while. If anyone has done this mod(I have the 1jz conversion, 3" exhaust, k&N filter and run around 13-14psi) Am i gonna get bang for my buck?
Old 04-19-2006, 09:27 AM   #2
ddmcse
ddmcse's Avatar
it's not going to be anywhere near as big a bang as the 3" exhaust
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-19-2006, 09:19 PM   #3
Troyota
Troyota is on a distinguished road
A bigger intercooler may make the turbos spool a bit slower. It will however allow more power to be had in conjunction w/ other modifications. If you are planning on adding a lot more power to your engine then an upgraded intercooler would be a good idea. However, the 1JZ intercooler is better than the 7M intercooler...in fact a lot of 7M owners will switch to the 1JZ intercooler especially when doing a front facing intake manifold moddification. Your 1JZ intercooler should be fine w/ the mods you have done and if you don't plan on making a whole lot more power.
1987 N/A MA70 Supra <--1JZ swap in progress
1986 AE86 GT-S Hatchback
2002 DC5 RSX Type S
Troyota is offline   Reply With Quote
Old 04-20-2006, 07:02 PM   #4
Burn N' Up
Burn N' Up's Avatar
Hehe, you can always boost your coolers performance with a little Cry02... =b
Old 04-21-2006, 08:29 AM   #5
SCRAMJET
SCRAMJET's Avatar
i have the 7M intercooler. I've done the 1jz conversion but haven't changed the intercooler. So maybe it is worth changing?
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Hoses?????? h8z2luze MKIII Supra 0 03-12-2008 06:40 AM
Clean out your intercooler!! IHateHacks MKIII Supra 4 10-25-2007 08:33 AM
Vacuum Hoses and Diagrams kewlcoconut MKIII FAQ 11 08-13-2007 01:41 AM
intercooler Mkiv shadowmaster05 MKIV Supra 1 03-20-2006 02:08 PM
