#1 |
Supra's like when i you ram a screw driver through the cats... The EPA doesn't
#2 |
I've been thinking about eliminating the cat that's right near the turbo and also using some kind of spring loaded "cut-out" before the rear cat. Shouldn't be too hard to get spring that keeps the bypass/dump closed until the boost comes in.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein 1988 and 1990 Turbo Supras |
#3 |
I see that the Mark IV TT has ~11.5 lb boost and ~300 HP. So what approx. HP will a Mark III make at 11.5? What differences are there besides the twin turbos?
| Thread | Thread Starter | Forum | Replies | Last Post |
| wont hold boost | Supraman | MKIII Supra | 12 | 04-19-2007 04:52 AM |
| new here and thinking about getting a Supra | WhisPer | MKIV FAQ | 20 | 03-17-2007 01:35 PM |
| issue w/ boost spikes? i think? | NOTORIOUS VR | Non-Generation Specific Questions | 17 | 01-17-2007 08:35 PM |
| No boost in neutral but boost in gear! | edgardo | MKIII Supra | 5 | 10-09-2004 04:01 AM |
