Old 04-10-2006, 12:50 AM   #1
flnbobpogoman
flnbobpogoman's Avatar
flnbobpogoman is on a distinguished road
Exclamation Need help with a 89 7m-gte
Hi all i seriously need help...i just bought a toyota supra 1989 Turbo and i need help...when i hit the thorttle at 1/2 the boost gauge show me like 8.5 psi... when i FOT (full open thorttle) it goes to 10 psi and at like 4500 rpm it goes to 15 psi and i get some misfire or fuel cut this suck....whats the best way to control the boost to max 8 psi?? the waste gate is adjustable?? or mine is just broken?? did i have to buy a boost controller??
flnbobpogoman is offline   Reply With Quote
Old 04-10-2006, 12:59 AM   #2
flnbobpogoman
Exclamation
i just gone to my last schoo and we plugged a snap-on scanner on it (for the check engine light)....theres 2 code error...... the Knock Sensor and another (53 i think) turbo and air flow problem....
John
Old 04-10-2006, 01:42 AM   #3
flnbobpogoman
ill've just read some post...i heard about shimmed wastegate... i think mine is because both bolt have 4 shim behind each... maybe thats making me having that 15 psi??? ill tryed to remove 2 of the shim but the bolt is torqued but the wastegate still can move so i shimmed to the other side ( 2 shim to make the wastegate more far from the turbo) ive tryed it and the turbo dont seem to go more then 10 psi...but i cant really test it cuz the clutch is slipping
but adding or removing shims is a way to control the boost?
the car also have a 3? straight pipe (no cat) exhaust and a knN air filter...it also have arp torqued bolts.plz help me i wanna limit the turbo to 10 psi what should i do???
i also have the burned bulb dash light,antilock and check eingine light on
John
Old 04-10-2006, 03:00 AM   #4
1988gte
1988gte is on a distinguished road
I only have 4 washers and i hit maybe 10lbs of boost, I would just remove a washer or two. Get a boost controller to be safe and a good guage
1988gte is offline   Reply With Quote
Old 04-10-2006, 11:32 AM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
remove all washers from wastegate
buy a boost controller & a good gauge
don't adjust boost controller till you know what your car does stock
if you hit fuel cut once you start adjusting the boost, turn down the boost
Pics of my build.
Do a diagnostic first!
Old 04-10-2006, 09:24 PM   #6
flnbobpogoman
Exclamation
i removed 2 washers so there only 2 left...the boost is now 10 psi but i still get some misfire or bad air/fuel ratio (not sure) i got a faze boost gauge...its a kinda good one...i should left 2 washer and just buy a boost controller and all will be ok?
i bought the car like that (4 washers)
John
Old 04-10-2006, 09:27 PM   #7
suprra_girl
7M POWAH! ;)
remove "all" washers and have it stock
then troubleshoot the car, if it's fine then install a boost controller (no more washers) and change you boost from there
Pics of my build.
Old 04-10-2006, 09:30 PM   #8
flnbobpogoman
Exclamation
okay so a manual boost control will be okay like this one..??
http://cgi.ebay.ca/TURBO-BOOST-CONTR...QQcmdZViewItem
John
Old 10-08-2006, 06:25 AM   #9
gomezmk
gomezmk is on a distinguished road
what kind of mods do you have such as intake system, I have the same problem
gomezmk is offline   Reply With Quote
Old 10-08-2006, 08:25 AM   #10
j3pz
then troubleshoot the car, if it's fine then install a boost controller (no more washers) and change you boost from there - quote supra_girl (didnt rephrase your post this time, just copyied it)
wow its almost like hes speaking another language or something
