Old 04-04-2006, 08:42 PM   #1
luggage
luggage is on a distinguished road
Default Safe jacking points
What are the safe jacking points for lifting the car from the front and rear so I can put jack stands under it. I couldn't find anything in the service manual except one picture under the rear axle section that almost looked like it was under the diff. (http://www.cygnusx1.net/supra/librar.../ra/RA_07.html top picture)
Thanks.
luggage is offline   Reply With Quote
Old 04-06-2006, 11:06 AM   #2
Burn N' Up
Burn N' Up's Avatar
jack under the rear diff and on the main front crossmember under the engine. Jack stands go on the frame rails just forward of the rear wheels and just aft of the front wheels. Be sure not to crush your fuel lines along the drivers rail.I've been jacking at the jack stands point without incident.
Old 04-06-2006, 11:18 AM   #3
ddmcse
ddmcse's Avatar
Cool
http://www.cygnusx1.net/supra/librar.../in/IN_12.html
vehicle lift and support locations
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-06-2006, 12:01 PM   #4
luggage
Great, thanks, both of you.
Max safe long straight performance in a road race? Humba MKIV Supra 7 12-25-2008 05:38 AM
newbie here (how much is safe? ) WhiteTurboZ89 MKIII Supra 2 01-05-2008 05:35 PM
Safe boosting for na-t supraman121 MKIII Supra 0 01-06-2007 08:13 PM
bhg points? supraman121 MKIII Supra 10 11-21-2006 02:07 PM
shift points thesandymancan MKIII Supra 3 02-26-2006 06:47 PM
