Old 04-01-2006, 09:43 PM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Default Vertical Fitting Under Throttle Body-1990
Anyone know what the vertical rubber hose fitting right under the throttle body connects to? I can't find any rubber hoses that fit it, can't see it (if it has one) on my other (1988 Turbo) Supra.
A 1987 service manual *seems* to say it's a water hose fitting--1 of 2 that go to the idle speed control (ISC) valve.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 04-01-2006, 10:06 PM   #2
ddmcse
ddmcse's Avatar
Cool
it is water
that connects to a hose the runs through the intake i forget exactly where it comes up from
http://www.cygnusx1.net/supra/librar...10/2211_2.html
lol this diagram is no help .
there should be a hose that comes up intake side in the mess of manifold
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-01-2006, 10:13 PM   #3
ddmcse
ddmcse's Avatar
Cool
i think i found it
http://www.ddmcse.com/turbo/images/remright.JPG
it's not the one dead center it's the one close to the wiring harness
see it right there next the tps connection ? the hose looks like it's been clamped thats the one
thats one reason why i took pictures .
My Supra KiXGaS
Old 04-01-2006, 10:48 PM   #4
Benesesso
Benesesso's Avatar
I see it plain as day on your car, but I can't find it on mine. Not on the car, my parts shelves, or the 1988 either. But it's obvious that my 1990 HAD the hose on there, because the metal fitting is clean and shiny.
Can you determine where the other end goes? The ser. man. says something about a "water pipe"--a real big help.
Old 04-02-2006, 01:10 AM   #5
Benesesso
Benesesso's Avatar
Found the hose--had to use a mirror to see it. Then had to pull the plenum back off to get to it. What a pain this car is.
Old 04-02-2006, 02:48 AM   #6
ddmcse
ddmcse's Avatar
Cool
the engine in the car is a pain in the ass .
the car is a dream to drive and that must be why we keep them
My Supra KiXGaS
Old 04-02-2006, 03:17 AM   #7
Benesesso
Benesesso's Avatar
True, but I don't know why the gas mileage is only around 21 mpg. I have never worked on a more difficult car before. It obviously wasn't meant to be serviced much, at least with the engine in the car.
I'm making a few changes to make the turbo-side a bit easier to reassemble. There is one stud on the downpipe that is very hard to reach and turn so I'm going to cut it off, drill it out and replace with a stainless bolt/nut.
I had planned on welding or brazing some fittings on the turbo oil lines, but now I think I'll just braze them back w/o the fittings. I'm not sure that it would be much easier to turn the fittings as to get to the bolts in the block. If the temp. wasn't so high in the area I use a length of good viton tubing so I could pull the turbo easily, but it's just too hot there.
BTW, the small oil-supply line is carbon steel but the big corrogated return is stainless.
Old 04-03-2006, 03:05 AM   #8
Benesesso
Benesesso's Avatar
After I re-lifted the plenum, and seeing how difficult it would be to attempt to reinstall that little 8 mm water hose to the "vertical fitting", I used a long piece of 5/16" fuel tubing and ran it down the side of the block. I used a double-ended barbed metal connector to join the two rubber hoses several inches under the plenum, where it's fairly easy to reach AFTER the plenum is back on.
I now realize that stripping the head bare while in the car was a real dumb thing to do. While I would NEVER do this BHG repair again this way, I'll have to think about how difficult it would be to pull the head with the turbo and intake manifold still on.
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
throttle body boogum7 MKIII Supra 5 12-21-2005 03:01 PM
