Old 03-31-2006, 06:03 PM   #1
Legionnaire
Legionnaire's Avatar
Legionnaire is on a distinguished road
Default My 1zgte bucks like a horse
my accord used to do this awhile back but it stopped doing it after i took it to a mechanic, but i never figured out why it did this...........i dont know if its the motor or the tranny
Legionnaire is offline   Reply With Quote
Old 04-03-2006, 12:07 PM   #2
when does it do it?
when you start boosting or idle or cruisng or what?
Old 04-04-2006, 04:59 PM   #3
Legionnaire
its always random..........some days it just wont do it at all.........then the next day the engine will rev up.......and the car will start bucking......so i let go of the gas, and slowly press it.......and most of the time it stops it from bucking...........
Old 04-05-2006, 01:01 AM   #4
rnoswal
rnoswal's Avatar
Sounds electrical. Could be your throttle positioning sensor or a bad connection to the distributor. Of course if your fuel pressure isn't right it could act in a similar way, bad fuel pump or connector there too.
Russ
Old 04-05-2006, 04:36 AM   #5
1988gte
Russ
Just did this and stopped for me. Do a pressue check i was getting arount 10-15 lbs
Old 04-05-2006, 05:28 AM   #6
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
i have a 7mgte and i am having a similar problem but only in 5th gear when i slam the throttle to the ground. it wont do it if i lightly get into it into boost then i can go all the way to the floor but if i snap it down from a cruise then it will buck and send a check engine light.
all the other gears i can slam them and have awsome power but 5th gear is just sensitive.
i checked the resistance on the tps and it is all good. i guess i need to try and see if i can pull a code or something. it feels like a miss fire or something but only in 5th gear.
djalkyd is offline   Reply With Quote
Old 04-05-2006, 05:52 AM   #7
dcrusupra
dcrusupra's Avatar
If it sends the check engine light, you've hit fuel cut.
New Rebuild
My CarDomain
Old 04-06-2006, 02:26 AM   #8
djalkyd
djalkyd's Avatar
well i guess i will have to go around the fuel cut then. damn i was hoping i wouldn't have hit it this early in the game.
bucks and spudders under boost? slowryders MKIII Supra 2 04-02-2008 03:11 AM
7GM using both a factory turbo and nonturbo cams for more horse cbs MKIII Supra 11 12-26-2006 08:20 PM
supra horse power Jeriko Suratos Non-Generation Specific Questions 5 06-24-2005 04:00 AM
