Old 03-29-2006, 05:03 AM   #1
katillidie
katillidie is on a distinguished road
Default mkIII probs, starts then dies and then not at all
ok, i got fuel, got spark... randomly she will crank up and run, then as a tease she shuts off, well we hooked a light up to the injector harness and as u turn the key the injector pulses twice then stops, when it pulses the car starts.... well we ran codes and came up with #14 ignition something or another..... well any ideas on what the hell this could be... the last owner said that his grand daughter was driving it home from school when it just cut off, so they pushed it home and it sat ever since untill my friend bought it. sooooo any help would be greatly appreciated. thanx
nick
katillidie is offline   Reply With Quote
Old 03-29-2006, 10:21 PM   #2
katillidie
Default help
bump need help please, i cant figure out whats wrong. i dont wanna go pay a miliopn dollars for a cpu and it not be the prob.......
Old 03-30-2006, 01:56 AM   #3
katillidie
Default codes
when we run the diagnostics it says number 14 and 51. 14 is the ignition switch but dunno even where to look, we have a haynes but it sux.. the 51 code has somethin to do with the a/c. any help would be greatly appreciated. thanx
Old 03-30-2006, 08:24 AM   #4
1988gte
1988gte is on a distinguished road
http://www.supras.org.nz/techinfo/TSRM/Default.htm Try this instead of the haynes. go step by step in the trouble shooting. My car was doing the same about 5 days ago, turned out to be the fuel pump. I had horrible fuel pressure. changed it and now its a beast again. Also when i first got the car it did the same thing, i unplugged the oxygen sensor and started right up and went fine. I was warned not to drive it with the oxygen sensor off because it could cause lean, rich problems. oh a new oxygen sensor (if it is the problem) is about $53.00 before shiping on this site http://oxygensensors.com hope this helps
1988gte is offline   Reply With Quote
