Old 02-16-2007, 09:03 PM   #1
brs86supra
brs86supra is on a distinguished road
Default need help figuring whats wrong
i just checked for codes and i am getting 13, 24, 31, 51. the car is idling really bad, i checked timing and its right. and i cant drive it it wont go above 2000rpm while moving, but can eventually make it that high while at a stop. its an 87 turbo 5spd. any advice willl be greatly appreciated.
brs86supra is offline   Reply With Quote
Old 02-16-2007, 10:48 PM   #2
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
Not sure about the errorr codes but it sounds like you have a massive boost leak. Check your intercooler hoses and clamps.
OmeGa is offline   Reply With Quote
Old 02-18-2007, 01:59 AM   #3
drmmr15
drmmr15 is on a distinguished road
Could be a clogged Cat also. Mine was clogged, and I had no boost, and wouldnt go above 4500RPM.
1987 Supra Turbo
GReddy TT
Open Element Filter (<---not sure what brand)
YAY BOOST!!!!....finally...
drmmr15 is offline   Reply With Quote
Old 02-19-2007, 12:19 AM   #4
sportriderseattle
sportriderseattle's Avatar
sportriderseattle is on a distinguished road
give this link a try and it should tell you atleast a bit about the codes.
http://cygnusx1.net/Supra/TechTips/e...ror_codes.aspx
Dan
http://www.cardomain.com/ride/2200872
1987 Toyota Supra Turbo Targa, 5 speed, Light blue, 67K miles, MKIV TT polished wheels
sportriderseattle is offline   Reply With Quote
Old 02-19-2007, 08:56 AM   #5
sd88supra
sd88supra is on a distinguished road
check your tps too. a mal adjusted or bad tps will give you idle problems. thats your code 51.
sd88supra is offline   Reply With Quote
Audio and a lot of other things wrong with car bluemeate MKIII Supra 4 05-18-2010 07:07 PM
My fenders look wrong Kristian_Wraae Non-Generation Specific Questions 14 05-07-2007 03:20 PM
intake manifold has coolant what did i do wrong? 91toy supra MKIII Supra 6 09-16-2006 02:46 PM
Stock Block Evilfurby MKIV Supra 56 01-09-2006 02:23 AM
