Old 03-13-2006, 01:19 PM   #1
brs86supra
brs86supra is on a distinguished road
Default hot start
after driving about a half an hour or so, and then when i cut the car off then leave it for a while, when i go into the store, then go back out and try to start it, the car idles rough and cuts off then i turn it on again and does the same thing so i press the gas and it putters and then shuts off. then i turn it on again and put it into drive, then press on the gas it accelerates real slow. could it be that i need to change the fuel filter, or something else, the car has 144k miles on it, and i dont think that it has been changed before, what else could it be?
brs86supra is offline   Reply With Quote
Old 03-14-2006, 02:11 PM   #2
brs86supra
does anyone have any clue to what this problem could be i cant figure it out. going to chang the fuel filter tomorrow and see what that does. is there an easier way of changing the filter besides lifting the car up off the ground, its kinda hard to get to
Old 03-14-2006, 02:35 PM   #3
supra_91
supra_91's Avatar
its a pain in the a$$ to get to
Old 03-14-2006, 08:27 PM   #4
kewlcoconut
kewlcoconut is on a distinguished road
i have the exact same problem man. i have no idea what it could be....im as stumped as you are
kewlcoconut is offline   Reply With Quote
Old 03-14-2006, 10:01 PM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
are your cars turbo?
have you both done diagnostics?
check for boost leaks or check the air flow meter is correctly plugged in
have either of you done the 12 volt mod to the fuel pump?
Pics of my build.
Do a diagnostic first!
Old 03-15-2006, 01:19 AM   #6
kewlcoconut
my car is not a turbo. 86.5 NA
i havent done a 12volt mod to the fuel pump. and the AFM is plugged in properly as well. mrnickleye said it could possibly be an EFI or ECU problem. I know mine is not a vacuum leak, I replaced every line and nothing leaks. My fuel filter was changed not too long ago as well, and the problem persisted.
Old 03-15-2006, 02:03 AM   #7
suprra_girl
7M POWAH! ;)
diagnostic?
Pics of my build.
Old 03-15-2006, 11:41 AM   #8
kewlcoconut
i havent done a diagnostic. what exactly would it tell me? would it narrow down the possible problems that it could be?
----------Errrrr Edit
brain is a little slow tonight...its like 4am. thought you were talking about running dyno tests...ugh i need sleep haha. i havent done a diagnostic recently because my engine light isnt on. being as stupid as i am, i didnt think of checking it. i will check it out tomorrow afternoon, see if i get a blink or two.
Old 03-15-2006, 11:45 AM   #9
suprra_girl
7M POWAH! ;)
it very well may do
Pics of my build.
Old 03-16-2006, 03:15 AM   #10
kewlcoconut
well i ran a diagnostic today and nothing showed up. steady blinking light.......
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
