Old 03-11-2006, 10:36 AM   #1
BARRY
BARRY is on a distinguished road
Smile HELP with 7mGTE
Hey guys how are we all?
im new to the forum and would like some advice.
i own a ma70 supra, i was forced to remove my turbo kit in order to pass registration. the car was idoling perfectly before i swapped bak to a STD CT26 turbo and manifold.
Since passing reg and refitting the aftermarket turbo bak on... (TD04E HKS KIT) The car has had poor idol.
I belive it is the way i refitted the Distributor / Crank Sensor. (is this wat its called?) Is there a set procedure into refitting this part??? Is there A WORKSHOP spec from TOYOTA??
i DID mark the gears in the sensor prior to R&R and put bak on as accurately as i could.. Still Bad IDOL ;-((
Any help would much appreciated. Im excited to be a part of this big community.
Cheers
Barry
BARRY is offline   Reply With Quote
Old 03-12-2006, 11:48 PM   #2
BARRY
Default Bump
Hey guys is there no help with the distributor?
Cheers
Barry
Old 03-13-2006, 11:32 AM   #3
check out this thread and the links i posted... should sort out your timing if that's the issues
http://toyota-supra.info/forums/showthread.php?t=3891
Old 03-13-2006, 02:32 PM   #4
rnoswal
rnoswal's Avatar
WOW, that is a strict inspection. Are you going to have to do that every time you get it inspected too? Sounds like Germany where almost all mods have to be factory mods or they are not acceptable. It must have been a very knowledgable person to have picked up on the mods.
Russ
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
