Old 03-10-2006, 11:08 AM   #1
XtreeX
XtreeX is on a distinguished road
Default Change the climate cntrl color?
Has anyone changed the color of the climate control unit from green to another color? I really want to change my dash from green to something else (not that i dont like green) and want to change the climate control as well so it matches. Its not a big deal, i was just curious.
Along with this would be the iginition light.
Thanks!
XtreeX is offline   Reply With Quote
Old 03-11-2006, 12:55 AM   #2
dcrusupra
dcrusupra's Avatar
Pretty easy. I havent looked into doing the climate control yet. But people do offer to do it on a different supra forum. $60 for red. And $80 for white Just send him your unit and you'll get it back with a different color. I personally want to find a way to change the green on the clock. Cant find a way for it.
New Rebuild
My CarDomain
Old 03-11-2006, 01:15 AM   #3
TONY!
TONY!'s Avatar
You know fellas, I just sold my gauge cluster and it would have been so easy ot change the lights on those.
10 seconds takes care of all of them if laid out. heheh
I do have my climate control still.
Maybe I will go get that and see how that would be like.
Take pics of it and maybe do a write up...
That would be later though.
_____|_____
_________________
/OO]====(W)====[OO\
[___________________]
[ [O] ///______\\\ [O]_]
Old 03-11-2006, 01:51 AM   #4
XtreeX
well i know how to change the color of the gauges. Thats pretty straight forward and simple. The ignition and climate control on the other hand I havent really looked at. I have no problem opening mine up and checking but why damage it if someone has already done it and knows exactly what to do. But glad to hear it's possible.
Old 03-11-2006, 10:54 AM   #5
Burn N' Up
Burn N' Up's Avatar
There are bulbs behind each button, and they pop off. Also, behind each square plastic marker there is a bulb, just match voltage to an LED and solder away, no problem, doing mine blue. Be sure to get wide pattern LEDs.
Old 05-09-2008, 10:54 PM   #6
panblackrose
panblackrose's Avatar
panblackrose is on a distinguished road
I saw someone with a signature the other day that had blue climate control buttons. I want to do mine red, or maybe blue. Does anyone know what that guys name is? I keep looking and I am having no luck, he said something about pm'ing him about the climate color.
panblackrose is offline   Reply With Quote
Old 05-10-2008, 01:54 PM   #7
Chambers
Chambers's Avatar
Originally Posted by dcrusupra View Post
... I personally want to find a way to change the green on the clock. Cant find a way for it.
Well it can be done, granted I haven't taken apart the clock assembly but you do the same thing as what that person does to change the climate control number color, you just get a readout that is the same size and has the same pins on it, then replace it with the new one.
I though about doing this but finding a electronics store around here that has little tid-bits like that is a hard find. Good luck to everyone though!!
"Stuck in the 80's"
where and wha color is the speed sensor and rpm signal wire 88Tsupra MKIII Supra 6 03-16-2011 07:48 PM
Anybody do a color change? finaltable MKIII Supra 0 08-14-2007 05:01 PM
spark plug change supfoo514 MKIII Supra 4 06-30-2006 07:41 AM
Should I STILL change head gasket?? lifesnotfair MKIII Supra 7 01-13-2006 01:08 AM
ELECTRONIC CLIMATE CONTROL WHITETURBO MKIII Supra 1 02-12-2005 09:04 AM
